Hi Evelita
First, a question. Is the Main Menu.exe a Captivate project
or a Menubuilder project?? Reason I ask is because I publish most
of my work in exe format and have picked up a problem in trying to
have 2 or more Captivate exe files open at the same time, but it
seems to be OK if you use a Menubuilder exe as the main menu to
drive the other files.
If the above does not work for you, then you might want to
think about specifying the currently open file to open your Main
Menu.exe when it closes. My suggestion would be to use a button on
the last slide that would call up this project again. In a
nutshell, the sequence would be open Menu, Link to File x (menu
closes itself down), click on button on last slide of File x, File
x closes and Menu opens.
Luck and happiness
Andrew
