Hi JAR2010
Assuming we are talking about the same thing
, the blue lines aren't visible to your end user.
They are there for you as the Captivate developer so that you know
the path the mouse will travel. If you choose not to have mouse
movement, they aren't visible to you as the developer either. So
your worries are quite probably unfounded.
Not following you on downloading the slides as JPEGs. Do you
mean by your end user? Or are you possibly asking if you can obtain
the screen captures as individual images from Captivate to use
elsewhere? If you mean by the end user, I'm going to say it's
probably not possible. But if you mean by Captivate, you should be
able to look in the Library panel and export them from there.
Either individually or as a group.
Cheers... Rick
