CFWINDOW problem
Mar 24, 2008 Mar 24, 2008
Can't figure out why in two cfwindows created from main page, calendar in cfinput type="datefield" behaves differently depending on ORDER in which they created. Calendar icon became inactive in the second window if the first one was called and then closed. (The input field is still active for manual data entry). But if main page refreshed it's active again. In the first window the calendar active at any time without refreshing main page and when called in any order. These 2 windows are identical. Bahavior is the same with any settings of cfwindow attriburtes like refreshOnShow (true or false) and others. And if to switch the order of windows creation in main page, the calendar in the other pop-up window became frozen and first one previously inactive works fine. Is it a bug in CF8?
This is code in main page:
<cfajaximport tags="cfwindow, cfform, cfinput-datefield" >
<cfwindow title="WindowName1"
name="MyName1"
height="380"
modal="false"
refreshOnShow="true"
initShow="false"
source="../MySource1.cfm"/ >
<cfwindow title="WindowName2"
name="MyName2"
height="380"
modal="false"
initShow="false"
source="../MySource2.cfm"/ >
Calles for pop-up windows:
<a href="#" onclick="javascript:ColdFusion.Window.show(MyName1);">Title 1</a>
<a href="#" onclick="javascript:ColdFusion.Window.show(MyName2);">Title 2</a>
in called windows:
<cfform>
<cfinput type="datefield" name="FieldName1">
</cfform>
<cfform>
<cfinput type="datefield" name="FieldName2">
</cfform>
Advanced techniques
2.8K
Participant ,
I've tried using cfWindow and I found out that it's too buggy. It would work on FF but it wouldn't on IE and vice versa. And then when you add flash forms into it it just goes crazy. don't worry, there is perfect solution for it, CF_Window custom tag, it's free and it works great.
http://cfwindow.riaforge.org/
TiGGi, thank you for quick reply. Yes it works fine in Fireforks browser but our client has IE. We'll see what Adobe will say on this issue.
Guest
I find cfwindow buggy as well. And considering the touting that cf8 has cool features for Use Experience, I believe Adobe can do better if they put in more and Better resources into it. As a community we would all benefit from it... Unfortunately it seems that Adobe has adopted a "raising cows" business model for creating zillions of products. Another strategy would be partially "raising cows" but still got flagship products including Cold Fusion 8...
this strategy would be a win-win for Adobe and us.
yeah, sure, we all know better what Adobe should do and how than Adobe
does... :)
as for cfwindow and other cf8 ajax ui components - they are based on
ExtJS 1.0 js library. you can leverage pretty much any of the library's
functionality with a bit of digging and js coding... it is not that hard
and there are a lot of blogs on the subject.
you can, of course, use a different js library if you want to - they all
a relatively easy to implement. jQuery is my personal favourite...
on a brighter side, i hear that cf8 updater1 will include updated ExtJS
with a more and betetr built-in out-of-the-box functionality... but
don't hold me to that - i assume it can al change still before the
release...
Azadi Saryev
Sabai-dee.com
http://www.sabai-dee.com/
Guest
Mar 25, 2008 Mar 25, 2008
I heard on March 8 that the updater would be out "Very shortly..." but then I heard it would be early April. Digging deep into any of these libraries for me mainly involves with Opportunity Cost...
Were you able to find a workaround for the iframes inside a cfwindow problem?
Participant ,
Just like those before mine, I'm also having issues using <cfwindow> and <form>. I have my <cfwindow> appearing fin in both IE and FF, my issue is doing a validation on the form fields. As soon as the person hits the submit button, the parent page refreshes. If the validation fails the user has no idea unless they click the link again, which is a shotty implementation. I'm forced to do all my validations via JS...
Guest
Azadi,
After weighing options, I've decided to tackle the related YUI and Ext libraries (mainly Ext) pertaining to the CFWINDOW tag.
a) find them all (done);
b) minik the cfwindow script, removed the CFWINDOW tag call line -- the first line (done);
b) put my iframes related js on top of them, put the miniked cfwindowNew.js as the last script (done);
Tried,
results: no error but NOT working (the fancy presentation / CSS not present). I suspect problem lies with the b) step.
Thoughts?
Thanks.
@ AlwaysWannaLearn:
rtfm:
using <form> tag will submit to the form to the main page
using <cfform> tag will submit the form to the ajax ui control the form
is displayed in
Azadi Saryev
Sabai-dee.com
Participant ,
quote:
Originally posted by: Newsgroup User
@ AlwaysWannaLearn:
rtfm:
is displayed in
Azadi Saryev
Sabai-dee.com
Wow. I did not know that. Do I need to include or import in some ajax script in order to do this? So simply the <cfform> will submit to the same <cfwindow> instance so if the server-validation fails I can present the appropriate error message, or if everything went OK, display a "thanks" message?
@ AlwaysWannaLearn:
yes, correct.
read this:
http://www.coldfusionjedi.com/index.cfm/2007/10/31/Ask-a-Jedi-Why-isnt-my-form-reloading-the-whole-p...
then read through the cf8 cfml reference/cf8 developers guide (both
freely downloadable from adobe.com) for more info
hth
Azadi Saryev
Sabai-dee.com
ghfftttyyudsderycv76,
can you describe what is your problem with iframes?
i am a bit lost... ca't figure out what you are talking about or find
your other post where you describe the problem...
Azadi Saryev
Sabai-dee.com
Guest
Azadi,
If you have a javascript that set iframe designMode to On and its src to some dynamic data value and then point a cfwindow's source to the following template, you'll see the iframe's would not be activated. But the js and the following template would work just fine outside cfwindow. Thanks. Don
main page
<form id="nutsFrm" method="post">
<iframe name="out" id="out" src="Untitled1.html" contenteditable="true" style="width:300px; height:150px"></iframe><br/>
</form>
<form id="nutsFrm2" method="post">
<iframe name="nuts2" id="nuts2" style="width:300px; height:150px"></iframe><br/>
</form>
Don,
I will play with it later. It's 1AM here and I am a wee bit tired...
Will try to have a look at it tomorrow...
Azadi Saryev
Sabai-dee.com
Guest
Sure thing, Azadi, thanks. Don
Jul 19, 2017 Jul 19, 2017
I know this is an old post but I'm working with cfwindows in CF11, and I may have just figured out the problem.  After 9 years, I imagine it won't help the original poster, but what the hey.
In my project,  I have two CFWindows that allow the user to select the series of checkboxes and associate the records to two different data points.  So let's say I'm working with widgets that can go either into product A or product B.
If the user comes to the page and opens the cfwindow "Widgets in Product A", they make their selections, save, and all is good.  Likewise, if they come to the page and open the cfwindow "Widgets in Product B" and save, again, all is good.
But if the user comes to the page, opens A and then opens B, things break.  On saving, B sees not only the widgets selected in current cfwindows, but also in previous cfwindow.
Thought I was losing my mind, but the conclusion I came to was that A CFWINDOWS'S HTML REMAINS IN THE DOM AFTER THE WINDOW IS CLOSED. Perhaps not news to everyone, but it was to me.
My guess is the original problem lay in using the same id name for a field in both windows causing the JavaScript to use an unintentional value.  Making the var names unique worked for me. Hope this helps.
Jeff Wogan
Documentation
