12 Replies Latest reply on Oct 14, 2016 6:42 AM by miguelt22364182
    4k iMac (Late 2015) black screen flashing/flickering
    malcombkobe
      I recently picked myself up a 4k iMac because my old PC practically blew up. After using the iMac for few months now I noticed there are a few issues when using the brush tool in Photoshop. At first I thought nothing of it and figured it would be resolved within the next couple weeks or so considering I got the iMac the day they came out. I noticed it got worse and worse over time though. I didn't quite know exactly what the problem was but what was happening was while using Photoshop and occasionally Lightroom my screen would completely flash black. I've now narrowed the issue down to if I have the brush size anywhere between 225 and 500 pixels and move the brush off of the picture I am editing over to the tools panel section or adjustments area, my screen will black out and I notice the text looks a bit distorted for a bit but in a matter of seconds it fixes itself. In Lightroom however it hardly ever happens but when it does, it is caused by me pressing the alt/option key. I've read the the forums and noticed that the 2013 Macbook air had the same issue but apple released a fix for them. There are a few forums on the apple website about this but all they recommend is to disable the Use Graphics Processor Unit option in the performance tab of preferences. Pleas help, I cannot find a fix to this issue. (and yes I did download the newest update for photoshop for November of 2015 and it is still happening and it happened before downloading.)
        • 1. Re: 4k iMac (Late 2015) black screen flashing/flickering
          Mrinmay Majhi Adobe Employee
          Hi malcombkobe,
          Please follow the below steps and check if this helps.
          > Launch Photoshop
          > Click on Photoshop > Preferences > Camera Raw
          > Uncheck the option Use Display adaptor
          > Click on OK
          > Click on Photoshop > Preferences > Performance
          > Click on Advanced Settings
          > Change the Drawing mode to Basic
          > Uncheck Use OpenCL
          > Click on OK
          Restart Photoshop and check for the issue.
          Let me know if this helps.
          ~Mrinmay
          • 2. Re: 4k iMac (Late 2015) black screen flashing/flickering
            malcombkobe Level 1
            Under the Camera Raw preferences, there is no option for Use Display Adaptor that I can see. I followed your steps for setting the Draw mode to Basic and unchecking Use OpenCL but unfortunately this has changed nothing.
            • 3. Re: 4k iMac (Late 2015) black screen flashing/flickering
              Could you please check and confirm the version of Camera Raw and Photoshop you are using?
              ~Mrinmay
              • 4. Re: 4k iMac (Late 2015) black screen flashing/flickering
                malcombkobe Level 1
                Camera Raw Version: 9.3.0.506
                Photoshop Version: 14.23.59.59
                • 5. Re: 4k iMac (Late 2015) black screen flashing/flickering
                  matt_ingram
                  I am having the same problem, same iMac etc. I have tried a number of things to see if I can isolate the problem, detaching all peripherals, logging in as a different user etc. The problem still persists and will only stop happening when I change the state of the canvas, i.e. zoom in or out, which will give me maybe a couple minutes good grace to continue working in, but then the problem will start happening again.
                  System specs are as follows:
                  iMac (Retina 4K, 21.5-inch, Late 2015)
                  Processor: 3.1 GHz Intel Core i5
                  Memory: 16 GB 1867 MHz DDR3
                  Graphics: Intel Iris Pro Graphics 6200 1536 MB
                  Adobe Photoshop CS6 Version 13.0.6
                  Please help as this problem is a real problem for workflow.
                  • 6. Re: 4k iMac (Late 2015) black screen flashing/flickering
                    Please launch Photoshop.
                    Click on Help > System Info
                    Please post the system info here.
                    ~Mrinmay
                    • 7. Re: 4k iMac (Late 2015) black screen flashing/flickering
                      pitspits Level 1
                      Hello excuse me, i've recently bought the same mac and I'm having the same black screen flashing problems either with Lightroom (especially when using the brush) and with Photoshop.
                      i also have other problems when using Lightroom brush: the changes I try to apply are not applied fluently, but with delay and in square portions of the area at different times. i have filmed the problems   I'm having in a video that i can send id it can help to understand and solve. I have the same installed Adobe Lr CC and Adobe Photoshop CC on my old MacBookPro and it works perfectly there. Please help me, cause this is creating a strong negative impact on my workflow.
                      Adobe Lr CC
                      Photoshop CC
                      Camera Raw 9.3.1.520
                      PS
                      • 8. Re: 4k iMac (Late 2015) black screen flashing/flickering
                        malcombkobe Level 1
                        Adobe Photoshop Version: 2015.1.1 20151209.r.327 2015/12/09:23:59:59 CL 1055659  x64
                        Operating System: Mac OS 10.11.2
                        System architecture: Intel CPU Family:6, Model:71, Stepping:1 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, AVX, AVX2
                        Physical processor count: 4
                        Processor speed: 3100 MHz
                        Built-in memory: 8192 MB
                        Free memory: 4166 MB
                        Memory available to Photoshop: 6315 MB
                        Memory used by Photoshop: 70 %
                        Modifier Palette: Disabled.
                        Design Space: Disabled.
                        Artboards: Enabled.
                        3D Multitone Printing: Disabled.
                        Highbeam: Enabled.
                        Image tile size: 1028K
                        Image cache levels: 5
                        Font Preview: Medium
                        TextComposer: Latin
                        Display: 1
                        Main Display
                        High DPI Monitor
                        Display Bounds: top=0, left=0, bottom=1152, right=2048
                        OpenGL Drawing: Enabled.
                        OpenGL Allow Old GPUs: Not Detected.
                        OpenGL Drawing Mode: Normal
                        OpenGL Allow Normal Mode: True.
                        OpenGL Allow Advanced Mode: True.
                        AIFCoreInitialized=1
                        AIFOGLInitialized=1
                        OGLContextCreated=1
                        NumGLGPUs=1
                        NumCLGPUs=1
                        glgpu[0].GLVersion="2.1"
                        glgpu[0].IsIntegratedGLGPU=0
                        glgpu[0].GLMemoryMB=1536
                        glgpu[0].GLName="Intel(R) Iris(TM) Pro Graphics 6200"
                        glgpu[0].GLVendor="Intel Inc."
                        glgpu[0].GLVendorID=32902
                        glgpu[0].GLRectTextureSize=16384
                        glgpu[0].GLRenderer="Intel(R) Iris(TM) Pro Graphics 6200"
                        glgpu[0].GLRendererID=16925962
                        glgpu[0].HasGLNPOTSupport=1
                        glgpu[0].CanCompileProgramGLSL=1
                        glgpu[0].GLFrameBufferOK=1
                        glgpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="1.20"
                        glgpu[0].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[1638 4]
                        glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[8]
                        glgpu[0].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[16]
                        glgpu[0].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[16]
                        glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[16]
                        glgpu[0].glGetIntegerv[GL_MAX_DRAW_BUFFERS]=[8]
                        glgpu[0].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[4096]
                        glgpu[0].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[4096]
                        glgpu[0].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[60]
                        glgpu[0].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[16]
                        glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_PROGRAM]=1
                        glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_PROGRAM]=1
                        glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_SHADER]=1
                        glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_SHADER]=1
                        glgpu[0].extension[AIF::OGL::GL_EXT_FRAMEBUFFER_OBJECT]=1
                        glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_RECTANGLE]=1
                        glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_FLOAT]=1
                        glgpu[0].extension[AIF::OGL::GL_ARB_OCCLUSION_QUERY]=1
                        glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_BUFFER_OBJECT]=1
                        glgpu[0].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=1
                        clgpu[0].CLPlatformVersion="1.2 (Nov 18 2015 20:45:47)"
                        clgpu[0].CLDeviceVersion="1.2 "
                        clgpu[0].IsIntegratedCLGPU=1
                        clgpu[0].CLMemoryMB=1536
                        clgpu[0].CLName="Intel(R) Iris(TM) Pro Graphics 6200"
                        clgpu[0].CLVendor="Intel Inc."
                        clgpu[0].CLVendorID=16925952
                        clgpu[0].CLDriverVersion="1.2(Nov 18 2015 20:57:39)"
                        clgpu[0].CUDASupported=0
                        clgpu[0].CLBandwidth=6.2652e+10
                        clgpu[0].CLCompute=377.152
                        License Type: Subscription
                        Serial number: 96040382376805999971
                        Feature::photoshop/extended: ON
                        Feature::photoshop/standard: ON
                        Feature::photoshop/trial: OFF
                        Feature::32-Bit Layers: ON
                        Feature::CountTool: ON
                        Feature::Acrobat3D: ON
                        Feature::Measurement: ON
                        Feature::MATLAB: ON
                        Feature::VanishingPointMeasurement: ON
                        Feature::VanishingPoint3DSExport: ON
                        Feature::VanishingPointDXFExport: ON
                        Feature::Dicom: ON
                        Feature::VideoLayers: ON
                        Feature::Timeline: ON
                        Feature::ExtendedMenuBar: ON
                        Feature::3DPrint App: ON
                        Feature::ImageStack Creation: ON
                        Feature::ImageStack Editing: ON
                        Feature::32-Bit Painting: ON
                        Feature::ACRFilterAllowed: ON
                        Feature::ACRFilterAvailable: ON
                        Feature::ExportAssetsQueueFeature: OFF
                        Feature::Creative Cloud Staging: OFF
                        Feature::3DMultitonePrinting: OFF
                        Feature::Artboards: ON
                        Feature::Playground: OFF
                        Feature::Chording Palette: OFF
                        Application folder: /Applications/Adobe Photoshop CC 2015/
                        Photoshop scratch has async I/O enabled
                        Scratch volume(s):
                          Startup, 930.7G, 877.4G free
                        Required Plug-ins folder: /Applications/Adobe Photoshop CC 2015/Adobe Photoshop CC 2015.app/Contents/Required/Plug-Ins/
                        Primary Plug-ins folder: /Applications/Adobe Photoshop CC 2015/Plug-ins/
                        Installed components:
                           AdbePM.framework   AdbePM   2.4.00.1   1.
                           adobe_caps.framework   adobe_caps   9.0.0.28   1.584361
                           AdobeACE.framework   AdobeACE   2.20.02.35269   79.567158
                           AdobeAGM.framework   AdobeAGM   4.30.60.35269   79.567158
                           AdobeAXE8SharedExpat.framework   AdobeAXE8SharedExpat   3.8.0.34320   79.562390
                           AdobeAXEDOMCore.framework   AdobeAXEDOMCore   3.8.0.34320   79.562390
                           AdobeBIB.framework   AdobeBIB   1.2.03.35269   79.567158
                           AdobeBIBUtils.framework   AdobeBIBUtils   1.1.01   79.567158
                           AdobeCoolType.framework   AdobeCoolType   5.15.00.35269   79.567158
                           AdobeCrashReporter.framework   AdobeCrashReporter   7.2.2
                           AdobeExtendScript.framework   AdobeExtendScript   4.5.6.2   80.1017022
                           AdobeJP2K.framework   AdobeJP2K   1.2.2.35138   79.258941
                           AdobeLinguistic.framework      21429
                           AdobeMPS.framework   AdobeMPS   5.8.1.35138   79.566687
                           AdobeOwl.framework   AdobeOwl   5.2.9
                           AdobePDFL.framework   AdobePDFL   15.0.0.35285   79.156620
                           AdobePDFSettings.framework   AdobePDFSettings   1.4
                           AdobePIP.framework   AdobePIP   7.3.1.70
                           AdobeScCore.framework   AdobeScCore   4.5.6.2   80.1017022
                           AdobeSVGAGM.framework   AdobeSVGAGM   1.0.0.35144   79.566705
                           AdobeSVGRE.framework   AdobeSVGRE   6.0   79.566690
                           AdobeUpdater.framework   AdobeUpdater   6.0.0.1452   "52.338651"
                           AdobeXMP.framework   AdobeXMPCore   79.158325   79.158325
                           AdobeXMPFiles.framework   AdobeXMPFiles   79.158325   79.158325
                           AdobeXMPScript.framework   AdobeXMPScript   79.158325   79.158325
                           ahclient.framework   ahclient   2.0.0.1
                           AIDE.framework   AIDE   1.5.0.35433   79.568000
                           aif.framework   aif   6.0.00.1   1.
                           amtlib.framework   amtlib   9.0.0.89
                           boost_date_time.framework   boost_date_time   8.0.0.0
                           boost_signals.framework   boost_signals   8.0.0.0
                           boost_system.framework   boost_system   8.0.0.0
                           boost_threads.framework   boost_threads   8.0.0.0
                           Cg.framework   NVIDIA Cg
                           CIT.framework   CIT   2.3.6.35081   158203
                           CITThreading.framework   CITThreading_boost   2.3.6.35081   158203
                           dvaaudiodevice.framework   dvaaudiodevice   8.0.0.0
                           dvacore.framework   dvacore   8.0.0.0
                           dvamarshal.framework   dvamarshal   8.0.0.0
                           dvamediatypes.framework   dvamediatypes   8.0.0.0
                           dvametadata.framework   dvametadata   8.0.0.0
                           dvametadataapi.framework   dvametadataapi   8.0.0.0
                           dvametadataUI.framework   dvametadataUI   8.0.0.0
                           dvaplayer.framework   dvaplayer   8.0.0.0
                           dvatransport.framework   dvatransport   8.0.0.0
                           dvaui.framework   dvaui   8.0.0.0
                           dvaunittesting.framework   dvaunittesting   8.0.0.0
                           dynamiclink.framework   dynamiclink   8.0.0.0
                           ICUConverter.framework   ICUConverter   3.61   "gtlib_6.0" "." "21287"
                           ICUData.framework   ICUData   3.61   "gtlib_6.0" "." "21287"
                           ICUUnicode.framework   ICUUnicode   3.61   "gtlib_6.0" "." "21287"
                           LogSession.framework   LogSession   7.3.1.70
                           manta.framework   manta   1.0.00.1   1.
                           mediacoreif.framework   mediacoreif   8.0.0.0
                           PlugPlugExternalObject.framework      6.1.0.157
                           PlugPlugOwl.framework   PlugPlugOwl   6.1.0.157
                           UpdaterNotifications.framework   UpdaterNotifications   9.0.0.15   "9.0.0.15"
                           WRServices.framework   WRServices   11.0.0   11.0.0.1000
                        Required plug-ins:
                           3D Studio 16.1.1  ©2006-2016 Adobe Systems Incorporated - from the file “U3D.plugin”
                           Accented Edges 16.1.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Adaptive Wide Angle 16.1.1, Copyright © 2014-2016 Adobe Systems Incorporated - from the file “Adaptive Wide Angle.plugin”
                           Angled Strokes 16.1.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Average 16.1.1  ©1993-2016 Adobe Systems Incorporated - from the file “Average.plugin”
                           Bas Relief 16.1.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           BMP 16.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                           Camera Raw 9.3.1 (520), Copyright © 2015 Adobe Systems Incorporated - from the file “Camera Raw.plugin”
                           Camera Raw Filter 9.3.1 (520), Copyright © 2015 Adobe Systems Incorporated - from the file “Camera Raw.plugin”
                           Chalk & Charcoal 16.1.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Chrome 16.1.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Cineon 16.1.1  ©2002-2016 Adobe Systems Incorporated - from the file “Cineon.plugin”
                           Clouds 16.1.1  ©1993-2016 Adobe Systems Incorporated - from the file “Clouds.plugin”
                           Collada DAE 16.1.1  ©2006-2016 Adobe Systems Incorporated - from the file “U3D.plugin”
                           Color Halftone 16.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                           Colored Pencil 16.1.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           CompuServe GIF 16.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                           Conté Crayon 16.1.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Craquelure 16.1.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Crop and Straighten Photos 16.1.1  Copyright © 2003-2016 Adobe Systems Incorporated - from the file “CropPhotosAuto.plugin”
                           Crop and Straighten Photos Filter 16.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                           Crosshatch 16.1.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Crystallize 16.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                           Cutout 16.1.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Dark Strokes 16.1.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           De-Interlace 16.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                           Dicom 16.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “dicom.plugin”
                           Difference Clouds 16.1.1  ©1993-2016 Adobe Systems Incorporated - from the file “Clouds.plugin”
                           Diffuse Glow 16.1.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Displace 16.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                           Dry Brush 16.1.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Eazel Acquire 16.1.1  Copyright © 2007-2016 Adobe Systems Incorporated - from the file “EazelAcquire.plugin”
                           Entropy 16.1.1  ©2006-2016 Adobe Systems Incorporated - from the file “statistics.plugin”
                           Export Color Lookup Tables 16.1.1  Copyright ©2012-2016 Adobe Systems Incorporated - from the file “Export3DLUT.plugin”
                           Extrude 16.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                           FastCore Routines 16.1.1  ©1990-2016 Adobe Systems Incorporated - from the file “FastCore.plugin”
                           Fibers 16.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                           Film Grain 16.1.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Filter Gallery 16.1.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Flash 3D 16.1.1  ©2006-2016 Adobe Systems Incorporated - from the file “U3D.plugin”
                           Fresco 16.1.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Glass 16.1.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Glowing Edges 16.1.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Google Earth 4 KMZ 16.1.1  ©2006-2016 Adobe Systems Incorporated - from the file “U3D.plugin”
                           Graphic Pen 16.1.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Halftone Pattern 16.1.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           HDRMergeUI 16.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “HDRMergeUI.plugin”
                           HSB/HSL 16.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                           IFF Format 16.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                           IGES 16.1.1  ©2006-2016 Adobe Systems Incorporated - from the file “U3D.plugin”
                           Ink Outlines 16.1.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           JPEG 2000 16.1.1  Copyright © 2001-2016 Adobe Systems Incorporated - from the file “JPEG2000.plugin”
                           Kurtosis 16.1.1  ©2006-2016 Adobe Systems Incorporated - from the file “statistics.plugin”
                           Lens Blur 16.1.1, Copyright © 2002-2016 Adobe Systems Incorporated - from the file “Lens Blur.plugin”
                           Lens Correction 16.1.1, Copyright © 2002-2016 Adobe Systems Incorporated - from the file “Lens Correct.plugin”
                           Lens Flare 16.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                           Liquify 16.1.1, Copyright © 2001-2016 Adobe Systems Incorporated - from the file “Liquify.plugin”
                           Matlab Operation 16.1.1  ©1993-2016 Adobe Systems Incorporated - from the file “ChannelPort.plugin”
                           Maximum 16.1.1  ©2006-2016 Adobe Systems Incorporated - from the file “statistics.plugin”
                           Mean 16.1.1  ©2006-2016 Adobe Systems Incorporated - from the file “statistics.plugin”
                           Measurement Core 16.1.1  Copyright © 1993-2016 Adobe Systems Incorporated - from the file “MeasurementCore.plugin”
                           Median 16.1.1  ©2006-2016 Adobe Systems Incorporated - from the file “statistics.plugin”
                           Mezzotint 16.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                           Minimum 16.1.1  ©2006-2016 Adobe Systems Incorporated - from the file “statistics.plugin”
                           MMXCore Routines 16.1.1  ©1990-2016 Adobe Systems Incorporated - from the file “MMXCore.plugin”
                           Mosaic Tiles 16.1.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Multiprocessor Support 16.1.1  Copyright © 1990-2016 Adobe Systems Incorporated - from the file “MultiProcessor Support.plugin”
                           Neon Glow 16.1.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Note Paper 16.1.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           NTSC Colors 16.1.1  ©1993-2016 Adobe Systems Incorporated - from the file “NTSC Colors.plugin”
                           Ocean Ripple 16.1.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           OpenEXR 16.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                           Paint Daubs 16.1.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Palette Knife 16.1.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Patchwork 16.1.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Paths to Illustrator 16.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                           PCX 16.1.1  ©1989-2016 Adobe Systems Incorporated - from the file “PCX.plugin”
                           Photocopy 16.1.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Photoshop 3D Engine 16.1.1  ©2006-2016 Adobe Systems Incorporated - from the file “Photoshop3DEngine.plugin”
                           Photoshop Touch Copyright ©2013-2016 Adobe Systems Incorporated - from the file “PSDX.plugin”
                           Picture Package Filter 16.1.1  ©1993-2016 Adobe Systems Incorporated - from the file “ChannelPort.plugin”
                           Pinch 16.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                           Pixar 16.1.1  ©1989-2016 Adobe Systems Incorporated - from the file “Pixar.plugin”
                           Plaster 16.1.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Plastic Wrap 16.1.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           PLY 16.1.1  ©2006-2016 Adobe Systems Incorporated - from the file “U3D.plugin”
                           PNG 16.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                           Pointillize 16.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                           Polar Coordinates 16.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                           Portable Bit Map 16.1.1  ©1989-2016 Adobe Systems Incorporated - from the file “PBM.plugin”
                           Poster Edges 16.1.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           PRC 16.1.1  ©2006-2016 Adobe Systems Incorporated - from the file “U3D.plugin”
                           Radial Blur 16.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                           Radiance 16.1.1  ©2003-2016 Adobe Systems Incorporated - from the file “Radiance.plugin”
                           Range 16.1.1  ©2006-2016 Adobe Systems Incorporated - from the file “statistics.plugin”
                           Render Color Lookup Grid 16.1.1  Copyright ©2012-2016 Adobe Systems Incorporated - from the file “Export3DLUT.plugin”
                           Reticulation 16.1.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Ripple 16.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                           Rough Pastels 16.1.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Save for Web 16.1.1, Copyright © 1999-2016 Adobe Systems Incorporated - from the file “Save for Web.plugin”
                           ScriptingSupport 16.1.1, Copyright © 2016 Adobe Systems Incorporated - from the file “ScriptingSupport.plugin”
                           Shake Reduction 16.1.1, Copyright © 2014-2016 Adobe Systems Incorporated - from the file “Shake Reduction.plugin”
                           Shear 16.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                           Skewness 16.1.1  ©2006-2016 Adobe Systems Incorporated - from the file “statistics.plugin”
                           Smart Blur 16.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                           Smudge Stick 16.1.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Solarize 16.1.1  Copyright © 1993-2016 Adobe Systems Incorporated - from the file “Solarize.plugin”
                           Spaces 16.1.1, Copyright © 2015 Adobe Systems Incorporated - from the file “Spaces.plugin”
                           Spatter 16.1.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Spherize 16.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                           Sponge 16.1.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Sprayed Strokes 16.1.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Stained Glass 16.1.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Stamp 16.1.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Standard Deviation 16.1.1  ©2006-2016 Adobe Systems Incorporated - from the file “statistics.plugin”
                           STL 16.1.1  ©2006-2016 Adobe Systems Incorporated - from the file “U3D.plugin”
                           Sumi-e 16.1.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Summation 16.1.1  ©2006-2016 Adobe Systems Incorporated - from the file “statistics.plugin”
                           Targa 16.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                           Texturizer 16.1.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Tiles 16.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                           Torn Edges 16.1.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Twirl 16.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                           U3D 16.1.1  ©2006-2016 Adobe Systems Incorporated - from the file “U3D.plugin”
                           Underpainting 16.1.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Vanishing Point 16.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “VanishingPoint.plugin”
                           Variance 16.1.1  ©2006-2016 Adobe Systems Incorporated - from the file “statistics.plugin”
                           Virtual Reality Modeling Language | VRML 16.1.1  ©2006-2016 Adobe Systems Incorporated - from the file “U3D.plugin”
                           Water Paper 16.1.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Watercolor 16.1.1, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                           Wave 16.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                           Wavefront|OBJ 16.1.1  ©2006-2016 Adobe Systems Incorporated - from the file “U3D.plugin”
                           Wind 16.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                           Wireless Bitmap 16.1.1  ©1989-2016 Adobe Systems Incorporated - from the file “WBMP.plugin”
                           ZigZag 16.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                        Optional and third party plug-ins: NONE
                        Plug-ins that failed to load: NONE
                        Extensions:
                           Recent Files  1.0.0
                              /Applications/Adobe Photoshop CC 2015/Adobe Photoshop CC 2015.app/Contents/Required/CEP/extensions/com.adobe.ccx.start/index.html
                           Libraries  2.1.24
                              /Applications/Adobe Photoshop CC 2015/Adobe Photoshop CC 2015.app/Contents/Required/CEP/extensions/com.adobe.DesignLibraryPanel.html/index.html
                           Start  1.0.0
                           Adobe Color Themes  6.1.0
                              /Applications/Adobe Photoshop CC 2015/Adobe Photoshop CC 2015.app/Contents/Required/CEP/extensions/com.adobe.KulerPanel.html/index.html
                           Export As  2.4.0
                              /Library/Application Support/Adobe/CEP/extensions/com.adobe.webpa.crema/PSPanel/dialog.html
                           Device Preview  1.1.3
                              /Library/Application Support/Adobe/CEP/extensions/com.adobe.preview/PSPanel/panel.html
                           Share on Behance  3.0.0
                              /Applications/Adobe Photoshop CC 2015/Adobe Photoshop CC 2015.app/Contents/Required/CEP/extensions/com.adobe.behance.shareonbehance.html/index.htm l
                           Export As  2.4.0
                           com.adobe.preview.loader  1.1.3
                              /Library/Application Support/Adobe/CEP/extensions/com.adobe.preview/PSLoader/loader.html
                        Installed TWAIN devices: NONE
                        • 9. Re: 4k iMac (Late 2015) black screen flashing/flickering
                          francoiso80311216
                          Hi! same glitch here. I tried what you suggested, it did not work
                          • 10. Re: 4k iMac (Late 2015) black screen flashing/flickering
                            TatyRS
                            Hi everyone,
                            I have the sam iMac 4K, the latest version of Photoshop and I am experiencing the same problem as described by users malcomkobe, matt_ingram, pitspits.
                            Working in PS with this problem becomes a very hard task. I hope Adobe can fix asap because I bought this iMac only in order to work with my pictures in PS.
                            If needed, I have also some videos of the problem.
                            iMac 21.5-inches 4K Late 2015
                            Processor 3.3 Ghz Intel Core i7
                            Memory 16 GB DDR3
                            This is my System Info in PS (sorry if it is in Italian, I hope you can understand what you need):
                            Adobe Photoshop versione: 2015.1.1 20151209.r.327 2015/12/09:23:59:59 CL 1055659  x64
                            Sistema operativo: Mac OS 10.11.2
                            Architettura di sistema: Famiglia CPU Intel:6, Modello:71, Stepping:1 con MMX, Intero SSE, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, AVX, AVX2, HyperThreading
                            Conteggio processore fisico: 4
                            Conteggio processore logico: 8
                            Velocità processore: 3300 MHz
                            Memoria incorporata: 16384 MB
                            Memoria disponibile: 9534 MB
                            Memoria disponibile per Photoshop: 14237 MB
                            Memoria usata da Photoshop: 70 %
                            Palette modificatori: disattivato.
                            Design Space: attivato.
                            Tavole da disegno: attivato.
                            Stampa 3D a più tonalità: disattivato.
                            Highbeam: ^ 0 ®Dimensioni porzioni immagine: 1024 K
                            Livelli cache immagine: 4
                            Anteprima font: Media
                            Composizione testo: Latino
                            Monitor: 1
                            Monitor principale
                            Monitor alta risoluzione
                            Visualizza limiti: alto= 0, sinistra= 0, basso= 1152, destra= 2048
                            Disegno OpenGL: attivato.
                            OpenGL - Consenti GPU precedenti: Non rilevato.
                            OpenGL - Modalità disegno: Base
                            OpenGL - Consenti modalità normale: True.
                            OpenGL - Consenti modalità avanzata: True.
                            AIFOGLInitialized=1
                            OGLContextCreated=1
                            NumGLGPUs=1
                            NumCLGPUs=1
                            clgpu[0].CLBandwidth=6.72768e+10
                            clgpu[0].CLCompute=354.641
                            Tipo di licenza: Iscrizione
                            Numero di serie: 96040649495123836931
                            Feature::MATLAB: ON
                            Feature::Dicom: ON
                            Feature::Playground: ON
                            Cartella applicazione: /Applications/Adobe Photoshop CC 2015/
                            La memoria virtuale di Photoshop dispone di I/O asincrono attivato
                            Volumi di memoria virtuale:
                              Avvio, 951,8 GB, 901,0 GB disponibili
                            Cartella plug-in richiesti: /Applications/Adobe Photoshop CC 2015/Adobe Photoshop CC 2015.app/Contents/Required/Plug-Ins/
                            Cartella plug-in principali: /Applications/Adobe Photoshop CC 2015/Plug-ins/
                            Componenti installati (installed components):
                            Plug-in richiesti (required plug-ins):
                               3D Studio 16.1.1  ©2006-2016 Adobe Systems Incorporated - dal file “U3D.plugin”
                               Affresco 16.1.1, Copyright © 1991-2016 Adobe Systems Incorporated - dal file “Filter Gallery.plugin”
                               Applica texture 16.1.1, Copyright © 1991-2016 Adobe Systems Incorporated - dal file “Filter Gallery.plugin”
                               Asimmetria 16.1.1  ©2006-2016 Adobe Systems Incorporated - dal file “statistics.plugin”
                               Bagliore diffuso 16.1.1, Copyright © 1991-2016 Adobe Systems Incorporated - dal file “Filter Gallery.plugin”
                               Bassorilievo 16.1.1, Copyright © 1991-2016 Adobe Systems Incorporated - dal file “Filter Gallery.plugin”
                               Bordi brillanti 16.1.1, Copyright © 1991-2016 Adobe Systems Incorporated - dal file “Filter Gallery.plugin”
                               Camera Raw 9.3.1 (520), Copyright © 2015 Adobe Systems Incorporated - dal file “Camera Raw.plugin”
                               Carta da lettere 16.1.1, Copyright © 1991-2016 Adobe Systems Incorporated - dal file “Filter Gallery.plugin”
                               Cineon 16.1.1  ©2002-2016 Adobe Systems Incorporated - dal file “Cineon.plugin”
                               Collada DAE 16.1.1  ©2006-2016 Adobe Systems Incorporated - dal file “U3D.plugin”
                               Colore mezzetinte 16.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - dal file “Standard Multiplugin.plugin”
                               Colori NTSC  16.1.1  ©1993-2016 Adobe Systems Incorporated - dal file “NTSC Colors.plugin”
                               CompuServe GIF 16.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - dal file “Standard Multiplugin.plugin”
                               Contorni accentuati 16.1.1, Copyright © 1991-2016 Adobe Systems Incorporated - dal file “Filter Gallery.plugin”
                               Contorni con inchiostro 16.1.1, Copyright © 1991-2016 Adobe Systems Incorporated - dal file “Filter Gallery.plugin”
                               Contorni poster 16.1.1, Copyright © 1991-2016 Adobe Systems Incorporated - dal file “Filter Gallery.plugin”
                               Contorni strappati 16.1.1, Copyright © 1991-2016 Adobe Systems Incorporated - dal file “Filter Gallery.plugin”
                               Conté Crayon 16.1.1, Copyright © 1991-2016 Adobe Systems Incorporated - dal file “Filter Gallery.plugin”
                               Coordinate polari 16.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - dal file “Standard Multiplugin.plugin”
                               Core misurazione 16.1.1  Copyright © 1993-2016 Adobe Systems Incorporated - dal file “MeasurementCore.plugin”
                               Correzione obiettivo 16.1.1, Copyright © 2002-2016 Adobe Systems Incorporated - dal file “Lens Correct.plugin”
                               Cristallizza 16.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - dal file “Standard Multiplugin.plugin”
                               Curtosi 16.1.1  ©2006-2016 Adobe Systems Incorporated - dal file “statistics.plugin”
                               Deforma 16.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - dal file “Standard Multiplugin.plugin”
                               Deviazione standard 16.1.1  ©2006-2016 Adobe Systems Incorporated - dal file “statistics.plugin”
                               Dicom 16.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - dal file “dicom.plugin”
                               Distorsione curvilinea 16.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - dal file “Standard Multiplugin.plugin”
                               Eazel Acquire 16.1.1  Copyright © 2007-2016 Adobe Systems Incorporated - dal file “EazelAcquire.plugin”
                               Effetto acquerello 16.1.1, Copyright © 1991-2016 Adobe Systems Incorporated - dal file “Filter Gallery.plugin”
                               Effetto carboncino 16.1.1, Copyright © 1991-2016 Adobe Systems Incorporated - dal file “Filter Gallery.plugin”
                               Effetto carta bagnata 16.1.1, Copyright © 1991-2016 Adobe Systems Incorporated - dal file “Filter Gallery.plugin”
                               Effetto cromatura 16.1.1, Copyright © 1991-2016 Adobe Systems Incorporated - dal file “Filter Gallery.plugin”
                               Effetto fotocopia 16.1.1, Copyright © 1991-2016 Adobe Systems Incorporated - dal file “Filter Gallery.plugin”
                               Effetto increspatura 16.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - dal file “Standard Multiplugin.plugin”
                               Effetto incrinatura 16.1.1, Copyright © 1991-2016 Adobe Systems Incorporated - dal file “Filter Gallery.plugin”
                               Effetto intonaco 16.1.1, Copyright © 1991-2016 Adobe Systems Incorporated - dal file “Filter Gallery.plugin”
                               Effetto onda 16.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - dal file “Standard Multiplugin.plugin”
                               Effetto pennellate 16.1.1, Copyright © 1991-2016 Adobe Systems Incorporated - dal file “Filter Gallery.plugin”
                               Effetto punti 16.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - dal file “Standard Multiplugin.plugin”
                               Effetto retinatura 16.1.1, Copyright © 1991-2016 Adobe Systems Incorporated - dal file “Filter Gallery.plugin”
                               Effetto ritaglio 16.1.1, Copyright © 1991-2016 Adobe Systems Incorporated - dal file “Filter Gallery.plugin”
                               Effetto sfera 16.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - dal file “Standard Multiplugin.plugin”
                               Effetto sfumino 16.1.1, Copyright © 1991-2016 Adobe Systems Incorporated - dal file “Filter Gallery.plugin”
                               Effetto spatola 16.1.1, Copyright © 1991-2016 Adobe Systems Incorporated - dal file “Filter Gallery.plugin”
                               Effetto spirale 16.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - dal file “Standard Multiplugin.plugin”
                               Effetto spugna 16.1.1, Copyright © 1991-2016 Adobe Systems Incorporated - dal file “Filter Gallery.plugin”
                               Effetto vento 16.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - dal file “Standard Multiplugin.plugin”
                               Entropia 16.1.1  ©2006-2016 Adobe Systems Incorporated - dal file “statistics.plugin”
                               Esporta tavole di consultazione colore 16.1.1  Copyright ©2012-2016 Adobe Systems Incorporated - dal file “Export3DLUT.plugin”
                               Estrusione 16.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - dal file “Standard Multiplugin.plugin”
                               Fibre 16.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - dal file “Standard Multiplugin.plugin”
                               Filtro Camera Raw 9.3.1 (520), Copyright © 2015 Adobe Systems Incorporated - dal file “Camera Raw.plugin”
                               Filtro Pacchetto immagini 16.1.1  ©1993-2016 Adobe Systems Incorporated - dal file “ChannelPort.plugin”
                               Filtro ritaglia e raddrizza foto 16.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - dal file “Standard Multiplugin.plugin”
                               Flash 3D 16.1.1  ©2006-2016 Adobe Systems Incorporated - dal file “U3D.plugin”
                               Fluidifica 16.1.1, Copyright © 2001-2016 Adobe Systems Incorporated - dal file “Liquify.plugin”
                               Formato file bitmap 16.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - dal file “Standard Multiplugin.plugin”
                               Formato IFF 16.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - dal file “Standard Multiplugin.plugin”
                               Formato PNG 16.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - dal file “Standard Multiplugin.plugin”
                               Formato Targa 16.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - dal file “Standard Multiplugin.plugin”
                               Fuoco prospettico 16.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - dal file “VanishingPoint.plugin”
                               Galleria filtri 16.1.1, Copyright © 1991-2016 Adobe Systems Incorporated - dal file “Filter Gallery.plugin”
                               Gessetto e carboncino 16.1.1, Copyright © 1991-2016 Adobe Systems Incorporated - dal file “Filter Gallery.plugin”
                               Google Earth 4 KMZ 16.1.1  ©2006-2016 Adobe Systems Incorporated - dal file “U3D.plugin”
                               Grana pellicola 16.1.1, Copyright © 1991-2016 Adobe Systems Incorporated - dal file “Filter Gallery.plugin”
                               Grandangolo adattato 16.1.1, Copyright © 2014-2016 Adobe Systems Incorporated - dal file “Adaptive Wide Angle.plugin”
                               Granulosità 16.1.1, Copyright © 1991-2016 Adobe Systems Incorporated - dal file “Filter Gallery.plugin”
                               HDRMergeUI 16.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - dal file “HDRMergeUI.plugin”
                               HSB/HSL 16.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - dal file “Standard Multiplugin.plugin”
                               IGES 16.1.1  ©2006-2016 Adobe Systems Incorporated - dal file “U3D.plugin”
                               Increspatura oceano 16.1.1, Copyright © 1991-2016 Adobe Systems Incorporated - dal file “Filter Gallery.plugin”
                               Intermedio 16.1.1  ©2006-2016 Adobe Systems Incorporated - dal file “statistics.plugin”
                               Intervallo 16.1.1  ©2006-2016 Adobe Systems Incorporated - dal file “statistics.plugin”
                               Involucro di plastica 16.1.1, Copyright © 1991-2016 Adobe Systems Incorporated - dal file “Filter Gallery.plugin”
                               JPEG 2000 16.1.1  Copyright © 2001-2016 Adobe Systems Incorporated - dal file “JPEG2000.plugin”
                               Luce al neon 16.1.1, Copyright © 1991-2016 Adobe Systems Incorporated - dal file “Filter Gallery.plugin”
                               Massimo 16.1.1  ©2006-2016 Adobe Systems Incorporated - dal file “statistics.plugin”
                               Matita colorata 16.1.1, Copyright © 1991-2016 Adobe Systems Incorporated - dal file “Filter Gallery.plugin”
                               Matlab Operation 16.1.1  ©1993-2016 Adobe Systems Incorporated - dal file “ChannelPort.plugin”
                               Media 16.1.1  ©1993-2016 Adobe Systems Incorporated - dal file “Average.plugin”
                               Media 16.1.1  ©2006-2016 Adobe Systems Incorporated - dal file “statistics.plugin”
                               Mezzatinta 16.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - dal file “Standard Multiplugin.plugin”
                               Minimo 16.1.1  ©2006-2016 Adobe Systems Incorporated - dal file “statistics.plugin”
                               Modulo Photoshop 3D 16.1.1  ©2006-2016 Adobe Systems Incorporated - dal file “Photoshop3DEngine.plugin”
                               Muovi 16.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - dal file “Standard Multiplugin.plugin”
                               Nuvole 16.1.1  ©1993-2016 Adobe Systems Incorporated - dal file “Clouds.plugin”
                               Nuvole in differenza 16.1.1  ©1993-2016 Adobe Systems Incorporated - dal file “Clouds.plugin”
                               Ombra tratteggiata 16.1.1, Copyright © 1991-2016 Adobe Systems Incorporated - dal file “Filter Gallery.plugin”
                               OpenEXR 16.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - dal file “Standard Multiplugin.plugin”
                               Pastelli su superficie ruvida 16.1.1, Copyright © 1991-2016 Adobe Systems Incorporated - dal file “Filter Gallery.plugin”
                               Patchwork 16.1.1, Copyright © 1991-2016 Adobe Systems Incorporated - dal file “Filter Gallery.plugin”
                               Pattern mezzetinte 16.1.1, Copyright © 1991-2016 Adobe Systems Incorporated - dal file “Filter Gallery.plugin”
                               PCX 16.1.1  ©1989-2016 Adobe Systems Incorporated - dal file “PCX.plugin”
                               Penna grafica 16.1.1, Copyright © 1991-2016 Adobe Systems Incorporated - dal file “Filter Gallery.plugin”
                               Pennello a secco 16.1.1, Copyright © 1991-2016 Adobe Systems Incorporated - dal file “Filter Gallery.plugin”
                               Photoshop Touch Copyright ©2013-2016 Adobe Systems Incorporated - dal file “PSDX.plugin”
                               Pixar 16.1.1  ©1989-2016 Adobe Systems Incorporated - dal file “Pixar.plugin”
                               PLY 16.1.1  ©2006-2016 Adobe Systems Incorporated - dal file “U3D.plugin”
                               Portable Bit Map 16.1.1  ©1989-2016 Adobe Systems Incorporated - dal file “PBM.plugin”
                               Porzioni 16.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - dal file “Standard Multiplugin.plugin”
                               Porzioni mosaico 16.1.1, Copyright © 1991-2016 Adobe Systems Incorporated - dal file “Filter Gallery.plugin”
                               PRC 16.1.1  ©2006-2016 Adobe Systems Incorporated - dal file “U3D.plugin”
                               Radiance 16.1.1  ©2003-2016 Adobe Systems Incorporated - dal file “Radiance.plugin”
                               Rendering griglia di consultazione colore 16.1.1  Copyright ©2012-2016 Adobe Systems Incorporated - dal file “Export3DLUT.plugin”
                               Riduzione effetto mosso 16.1.1, Copyright © 2014-2016 Adobe Systems Incorporated - dal file “Shake Reduction.plugin”
                               Riflesso obiettivo 16.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - dal file “Standard Multiplugin.plugin”
                               Ritaglia e raddrizza foto 16.1.1  Copyright © 2003-2016 Adobe Systems Incorporated - dal file “CropPhotosAuto.plugin”
                               Routine FastCore 16.1.1  ©1990-2016 Adobe Systems Incorporated - dal file “FastCore.plugin”
                               Routine MMXCore 16.1.1  ©1990-2016 Adobe Systems Incorporated - dal file “MMXCore.plugin”
                               Salva per Web 16.1.1, Copyright © 1999-2016 Adobe Systems Incorporated - dal file “Save for Web.plugin”
                               Sfocatura con obiettivo 16.1.1, Copyright © 2002-2016 Adobe Systems Incorporated - dal file “Lens Blur.plugin”
                               Sfocatura migliore 16.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - dal file “Standard Multiplugin.plugin”
                               Sfocatura radiale 16.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - dal file “Standard Multiplugin.plugin”
                               Solarizza 16.1.1  Copyright © 1993-2016 Adobe Systems Incorporated - dal file “Solarize.plugin”
                               Sommatoria 16.1.1  ©2006-2016 Adobe Systems Incorporated - dal file “statistics.plugin”
                               Spaces 16.1.1, Copyright © 2015 Adobe Systems Incorporated - dal file “Spaces.plugin”
                               Spruzzo 16.1.1, Copyright © 1991-2016 Adobe Systems Incorporated - dal file “Filter Gallery.plugin”
                               STL 16.1.1  ©2006-2016 Adobe Systems Incorporated - dal file “U3D.plugin”
                               Sumi-e 16.1.1, Copyright © 1991-2016 Adobe Systems Incorporated - dal file “Filter Gallery.plugin”
                               Supporto multiprocessore 16.1.1  Copyright © 1990-2016 Adobe Systems Incorporated - dal file “MultiProcessor Support.plugin”
                               SupportoScripting 16.1.1, Copyright © 2016 Adobe Systems Incorporated - dal file “ScriptingSupport.plugin”
                               Timbro 16.1.1, Copyright © 1991-2016 Adobe Systems Incorporated - dal file “Filter Gallery.plugin”
                               Togli interlacciato 16.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - dal file “Standard Multiplugin.plugin”
                               Tracciati per Illustrator 16.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - dal file “Standard Multiplugin.plugin”
                               Tratti a spruzzo 16.1.1, Copyright © 1991-2016 Adobe Systems Incorporated - dal file “Filter Gallery.plugin”
                               Tratti ad angolo 16.1.1, Copyright © 1991-2016 Adobe Systems Incorporated - dal file “Filter Gallery.plugin”
                               Tratti scuri 16.1.1, Copyright © 1991-2016 Adobe Systems Incorporated - dal file “Filter Gallery.plugin”
                               U3D 16.1.1  ©2006-2016 Adobe Systems Incorporated - dal file “U3D.plugin”
                               Varianza 16.1.1  ©2006-2016 Adobe Systems Incorporated - dal file “statistics.plugin”
                               Vernice di fondo 16.1.1, Copyright © 1991-2016 Adobe Systems Incorporated - dal file “Filter Gallery.plugin”
                               Vetro 16.1.1, Copyright © 1991-2016 Adobe Systems Incorporated - dal file “Filter Gallery.plugin”
                               Vetro colorato 16.1.1, Copyright © 1991-2016 Adobe Systems Incorporated - dal file “Filter Gallery.plugin”
                               Virtual Reality Modeling Language | VRML 16.1.1  ©2006-2016 Adobe Systems Incorporated - dal file “U3D.plugin”
                               Wavefront|OBJ 16.1.1  ©2006-2016 Adobe Systems Incorporated - dal file “U3D.plugin”
                               Wireless Bitmap 16.1.1  ©1989-2016 Adobe Systems Incorporated - dal file “WBMP.plugin”
                               Zig zag 16.1.1, Copyright © 2003-2016 Adobe Systems Incorporated - dal file “Standard Multiplugin.plugin”
                            Plug-in opzionali e di terze parti: NESSUNO
                            Impossibile caricare i seguenti plug-in: NESSUNO
                            Estensioni (Extensions):
                               Recent Files  1.0.0
                               Librerie  2.1.24
                               Start  1.0.0
                               Temi Adobe Color  6.1.0
                               Esporta come  2.4.0
                               Condividi su Behance  3.0.0
                               Esporta come  2.4.0
                            Periferiche TWAIN installate: NESSUNA
                            • 11. Re: 4k iMac (Late 2015) black screen flashing/flickering
                              JumpBranding
                              Hello!
                              We have the exact same problems on 6 late 2015 iMacs 16gb ram (elcap), and some of our designers have it constantly and consistently throughout the day. It's not just photoshop, indesign and illustrator too.
                              Hoping to see a resolution to this soon!
                              • 12. Re: 4k iMac (Late 2015) black screen flashing/flickering
                                miguelt22364182
                                I've had this problem ever since I bought mine, 3 months ago. Nothing that Apple Care suggested seemed to work. Then, while fiddling cluelessly with the System Settings, I may have fixed it.
                                Go to Displays, choose "Scaled", and then select some resolution other than "default". Then, where you chose "Scaled", change back to "Default". This did the trick for me. Immediately after that, the flashes stopped and it's been a couple of weeks now.
                                By the way, this bug is not exclusive to Photoshop. It happens whenever a custom cursor changes back to a default one. Even some websites (like zappos) can suffer from this.
