quote:
Originally posted by: Michele in the Library
Currently, I'm working with Captivate 3 and PowerPoint 2007. I figured out that we can't import pptx files but have to convert back to ppt or pps - no problem there. However, I'm still having serious issues with color conversion. When I import a ppt (or pps, I've tried both) file into Captivate, a certain theme color in my show turns into this seafoam green/light blue color. Now, the color I was initially using was a standard dark blue, but I've since changed it to various other standard colors to try and work around the issue, with no luck. They all turn seafoam. I've also tried adjusting the color settings within captivate (under preferences) to no avail. Is anyone else having this issue or aware of a fix?
quote:
Originally posted by: Captiv8r
Hi again mhelotie
Most Microsoft applications allow you to save in an earlier format. Have you tried this? Maybe that will allow you to get the PowerPoint in?
Might be worth trying.
As a side note, I'd be willing to be we see several improvements with Captivate next. Especially since version 3 was the first one under the Adobe banner.
Cheers... Rick
