Adding Tracking URLs for Google Analytics
Mar 26, 2008 Mar 26, 2008
How do I add a tracking URL to every help page within the help system? I'm using RoboHelp 7, producing WebHelp. Thank you!
825
Explorer , Mar 27, 2008 Mar 27, 2008
Thank you so much! Yes, I got my snippet. I just had no clue what to do with it. I didn't know that I could reapply templates. Thanks!
Hi Angela
Near as I can tell, this is all handled using JavaScript. It should be a reasonably simple matter to connect it all up. I think I'd probably shoot for using a .JS file linked to each topic. Not sure though how it all operates. I'm unsure if each topic needs a specific identifier in the code or what.
Cheers... Rick
You're right, JavaScript is what's used. The biggest mystery to me is where (dir) to put the code. I don't want to regenerate the source, only to find out that I overwrite the directory. Well, if you find a related archived topic, let me know. I've searched, but no luck. I'm thinking of just emailing Adobe Technical Support.
Participant ,
Google should give you a snippet of code to attach to every page that you want tracked. Something like:
quote:
<script src=" http://www.google-analytics.com/urchin.js" type="text/javascript">
</script>
<script type="text/javascript">
_uacct = "UA-YOURNUMBER";
urchinTracker();
</script>
Put that in the footer for every topic. The easiest way is to put it in your topic template and reapply the template(s) to your topics. Unless Analytics has changed (been a while since I've used it) you don't have to attach a .js file to your project. The above script calls the Analytics server with your account number and visitor information. I love using Analytics for reporting and traffic monitoring, very good and free. Hope that helps.
Lucas,
Based on the text in my default template, there is a Header and Footer button in the toolbar. I don't see such a button. Can you shed some light on header/footers? Thank you!
By the way, I put my java script in <head></head> tag, then applied the template to a test topic, but the test topic didn't update.
Hi again Angela
This is RoboHelp HTML, no?
If so, you should be able to do the following:
* Click View > Pods > Project Setup
* Right-click the Templates pseudo-folder and choose "New Topic Template"
* Name the Template and click OK
* Click View > Footer (Or View > Header - But Footer is probably more clean for this)
* Click Insert > HTML > Advanced > Script
* Paste your snippet of code and click OK (You should see red boxes in your footer)
* Click Window > Close all
* Click View > Pods > Topic List
* Press Ctrl+A to select all topics
* Right-click the selection and choose Properties
* Click the General tab
* Click the drop-down and choose your template, then click OK. It should then apply the footer to all the topics in your project.
That should get you pretty near to what you are seeking.
Cheers... Rick
Apr 01, 2008 Apr 01, 2008
Thank you everyone for your help. Yes, it's working now. At first I was getting an error in Google Analytics, but fixed the problem: Don't make the mistake I made. Don't add <script type="text/javascript"> and </script> tags because RoboHelp adds them by default.
RoboHelp Documentation
Download Adobe RoboHelp
