I have good internet connection but continually get this message- on a windows 7 laptop
Hi Ken,
There could be many reasons for this one. Typically I see it occurring on networks where port 8080 is blocked. Are you on a home network (shouldn't be blocked here) or a school/corporate network? Do you use a firewall that might be blocking that port? If a school or corporate network you might have to contact the system administrator and ask them to open the port. I'd recommend that you try a different network if possible.
so on the home network-- any additional ideas- I should not have any closed ports. - I have downloaded to adobe digital editions in the past- just has not worked past 2 days with multiple books
You can check to make sure here: Open Port Check Toolā. Put in port 8080 and run the check.
Have you changed anything on your computer or network in the past two day? You could attempt a reinstall of ADE 4.5 and see if that might help. Download | Adobe Digital Editions
