Show 5 replies
1. Re: Flash in DW CS3 template issues
UniqueCreations Mar 30, 2008 10:07 AM (in response to UniqueCreations)I have found a work around. It seems that whenever I make a change to the template and save it, after it updates the pages that use the template file is where the Flash is getting messed up. So as a work around I need to copy the content of the editable region for the page that I want to fix. Then create a new page from the template. Paste the copied content in the editable region, and then save the page overwriting the existing page in question.
While this works, it seems a bit redundant and I would much rather figure out how to get this to work properly. -
2. Re: Flash in DW CS3 template issues
Newsgroup_User Mar 30, 2008 10:09 AM (in response to UniqueCreations)Make the link to the Flash file a ROOT relative link in the Template. Do
that by changing this -
AC_FL_RunContent(
'codebase',' http://download.macromedia.com/pub/shockwave/cabs/flash/swflash.cab#version=9,0,28,0','wid th','780','height','200','src','spirit_life_header','quality','high','pluginspage','http:/ /www.adobe.com/shockwave/download/download.cgi?P1_Prod_Version=ShockwaveFlash','movie','sp irit_life_header'
); //end AC code
</script><noscript>
<object classid="clsid:D27CDB6E-AE6D-11cf-96B8-444553540000"
codebase=" http://download.macromedia.com/pub/shockwave/cabs/flash/swflash.cab#version=9,0,28,0"
width="780" height="200">
<param name="movie" value="spirit_life_header.swf" />
<param name="quality" value="high" />
<embed src="spirit_life_header.swf" quality="high"
pluginspage=" http://www.adobe.com/shockwave/download/download.cgi?P1_Prod_Version=ShockwaveFlash"
type="application/x-shockwave-flash" width="780" height="200"></embed>
</object>
</noscript>
to this -
AC_FL_RunContent(
'codebase',' http://download.macromedia.com/pub/shockwave/cabs/flash/swflash.cab#version=9,0,28,0','wid th','780','height','200','src','/spirit_life_header','quality','high','pluginspage','http: //www.adobe.com/shockwave/download/download.cgi?P1_Prod_Version=ShockwaveFlash','movie','/ spirit_life_header'
); //end AC code
</script><noscript>
<param name="movie" value="/spirit_life_header.swf" />
<embed src="/spirit_life_header.swf" quality="high"
</object>
</noscript>
Then make sure that a) the file 'spirit_life_header.swf' is IN THE ROOT
FOLDER.
Murray --- ICQ 71997575
Adobe Community Expert
(If you *MUST* email me, don't LAUGH when you do so!)
http://www.projectseven.com/go - DW FAQs, Tutorials & Resources
http://www.dwfaq.com - DW FAQs, Tutorials & Resources
"UniqueCreations" <webforumsuser@macromedia.com> wrote in message
news:fsofjc$a7r$1@forums.macromedia.com...
>I have created a template which contains a Flash header at the top. After
> creating new pages using the template, some of the pages are not loading
> the
> Flash movie for some reason. The index page does, but none of the
> others.The
> Flash does not reside in an editable region, so why would it not load in
> any of
> the pages. Here is the project in question:
> http://uniquecreationsdesign.com/spiritlife/
> I have just started creating the pages from the template and linking them
> up.
> As it is right now there are only the first two links, but already having
> the
> issue and I don't want to continue until I can get this issue sorted out.
> The
> strange thing about this problem is that from DW, if I view the pages in
> question locally there is nothing at the top, no Flash at all. Once
> uploaded to
> the server and viewed remotely I see the Flash container but no movie
> loads.
> Any help here? I greatly appreciate in advance and light you can shed on
> this
> issue.
3. Re: Flash in DW CS3 template issues
UniqueCreations Mar 30, 2008 2:31 PM (in response to Newsgroup_User)Well the code in DW is slightly different than what you are getting from the view source on the remote page. Here is the DW code: -
4. Re: Flash in DW CS3 template issues
UniqueCreations Mar 30, 2008 2:35 PM (in response to UniqueCreations)I just tried changing the settings for the SWF file to "relative to site root" which did change the code to what you had suggested. However, still if I make a paage from template it is not giving me the Flash header. -
5. Re: Flash in DW CS3 template issues
Newsgroup_User Mar 30, 2008 3:00 PM (in response to UniqueCreations)> which did change the code to what you had suggested. However, still if I
> make a
Post a link to one where you have done this, please.
news:fsp131$sie$1@forums.macromedia.com...
>root"
> make a
