Is there another reader for EPub Fixed Lay out than Digital Editions for Windows? Digital Editions don't let the text see the way it should.
I know the Online Publishing, but I want a reader, just like Acrobat Reader that shows the document offline.
Its exist only Digital Edition for Windows PC.
Tnanx for your reply Nanaky.
Unfortunaly it doens'nt show the document in the good way. I Hope that Adobe will change it with an update.
You can also try it with a older version: http://www.adobe.com/support/digitaleditions/downloads.html
The current Version of Digital Edition has any problems.
Ok. I will try that.
I tried it. It is even worse. Maby because the interactive version is availible from march 2015.
I believe Calibre will read epub as well as mobi and others.
Fine.
Thank for your tip RogerOsborn.
The fonts looks good, only the buttons don't work and the page size is to large.
I have just tried Calibre and all the buttons worked fine. You can adjust the font size and if the page is too big you can just resize the window. Just click the Maximise/Restore Down button in the upper right corner of the Calibre e-book viewer.
