2 Replies Latest reply on Dec 12, 2015 4:44 PM by matt_ingram
    Screen keeps flickering black, Photoshop, iMac 4k
    matt_ingram Level 1
      This problem seems to be occurring with quite a few people. I've been on the phone to Apple about it and have even consulted their senior team on the problem. It seems to be a screen compatibility issue as even when I detached all other peripherals, wacom tablet, external monitor etc, the problem still continued. I've also tried all the other work arounds that Adobe have suggested on their forums. The problem occurs when I use the Alt or Space bar, plus other commands (however not the Command key, that doesn't seem to affect it) in Photoshop CS6, and CS5, the screen will intermittently flash black which really upsets workflow. Neither Adobe nor Apple have made any announcements to suggest that either company is going to be fixing this issue yet and it would be really great if someone could sort this problem out as I mostly use my computer for photoshop as I'm sure many other users do as well. It's important that this issue continues to be raised, has anyone found a work-around for it yet?
      System specs are as follows:
      iMac (Retina 4K, 21.5-inch, Late 2015)
      Processor: 3.1 GHz Intel Core i5
      Memory: 16 GB 1867 MHz DDR3
      Graphics: Intel Iris Pro Graphics 6200 1536 MB
      Adobe Photoshop CS6 Version 13.0.6
        • 1. Re: Screen keeps flickering black, Photoshop, iMac 4k
          Mrinmay Majhi Adobe Employee
          Hi matt_ingram,
          I am sorry for the inconvenience caused to you.
          Could you please check and confirm which version of Mac operating system are you using?
          Launch Photoshop.
          Click on Help > System Info
          Please post the system info here.
          ~Mrinmay
          • 2. Re: Screen keeps flickering black, Photoshop, iMac 4k
            matt_ingram Level 1
            I am running El Capitan, 10.11.2. I was instructed to update to the latest version after my conversation with Apple.
            Here is the system info from Photoshop CS6 13.0.6:
            Adobe Photoshop Version: 13.0.6 (13.0.6 20131025.r.54 2013/10/25:21:00:00) x64
            Operating System: Mac OS 10.11.2
            System architecture: Intel CPU Family:6, Model:71, Stepping:1 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2
            Physical processor count: 4
            Processor speed: 3100 MHz
            Built-in memory: 16384 MB
            Free memory: 6037 MB
            Memory available to Photoshop: 13995 MB
            Memory used by Photoshop: 70 %
            Image tile size: 1024K
            Image cache levels: 4
            OpenGL Drawing: Enabled.
            OpenGL Drawing Mode: Advanced
            OpenGL Allow Normal Mode: True.
            OpenGL Allow Advanced Mode: True.
            OpenGL Allow Old GPUs: Not Detected.
            OpenCL Version: 2.1
            OpenGL Version: 2.1
            Video Rect Texture Size: 16384
            OpenGL Memory: 1536 MB
            Video Card Vendor: Intel Inc.
            Video Card Renderer: Intel(R) Iris(TM) Pro Graphics 6200
            Display: 2
            Display Depth: 32
            Display Bounds: top=22, left=-1920, bottom=1200, right=0
            Video Renderer ID: 16925962
            Video Card Memory: 1536 MB
            Display: 1
            Main Display
            High DPI Monitor
            Display Depth: 32
            Display Bounds: top=0, left=0, bottom=1152, right=2048
            Serial number: 92629224113498297797
            Application folder: /Applications/Adobe Photoshop CS6/
            Photoshop scratch has async I/O enabled
            Scratch volume(s):
              Startup, 232.6G, 151.0G free
            Required Plug-ins folder: /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Required/
            Primary Plug-ins folder: /Applications/Adobe Photoshop CS6/Plug-ins/
            Additional Plug-ins folder: not set
            Installed components:
               adbeape.framework   adbeape   3.3.8.19346   66.1025012
               AdbeScriptUIFlex.framework   AdbeScriptUIFlex   6.2.29.18602   66.490082
               adobe_caps.framework   adobe_caps   6.0.29.0   1.276181
               AdobeACE.framework   AdobeACE   2.19.18.20743   66.507768
               AdobeAGM.framework   AdobeAGM   4.26.20.20743   66.507768
               AdobeAXE8SharedExpat.framework   AdobeAXE8SharedExpat   3.7.101.18636   66.26830
               AdobeAXEDOMCore.framework   AdobeAXEDOMCore   3.7.101.18636   66.26830
               AdobeBIB.framework   AdobeBIB   1.2.02.20743   66.507768
               AdobeBIBUtils.framework   AdobeBIBUtils   1.1.01   66.507768
               AdobeCoolType.framework   AdobeCoolType   5.10.33.20743   66.507768
               AdobeCrashReporter.framework   AdobeCrashReporter   6.0.20120720
               AdobeExtendScript.framework   AdobeExtendScript   4.2.12.18602   66.490082
               AdobeJP2K.framework   AdobeJP2K   2.0.0.18562   66.236923
               AdobeLinguistic.framework      17206
               AdobeMPS.framework   AdobeMPS   5.8.0.19463   66.495174
               AdobeOwl.framework   AdobeOwl   5.0.4   79.517869
               AdobePDFL.framework   AdobePDFL   10.0.1.18562   66.419471
               AdobePDFSettings.framework   AdobePDFSettings   1.4
               AdobePIP.framework   AdobePIP   7.0.0.1686
               AdobeScCore.framework   AdobeScCore   4.2.12.18602   66.490082
               AdobeUpdater.framework   AdobeUpdater   6.0.0.1452   "52.338651"
               AdobeXMP.framework   AdobeXMPCore   66.145661   66.145661
               AdobeXMPFiles.framework   AdobeXMPFiles   66.145661   66.145661
               AdobeXMPScript.framework   AdobeXMPScript   66.145661   66.145661
               ahclient.framework   ahclient   1.7.0.56
               aif_core.framework   AdobeAIF   3.0.00   62.490293
               aif_ocl.framework   AdobeAIF   3.0.00   62.490293
               aif_ogl.framework   AdobeAIF   3.0.00   62.490293
               AlignmentLib.framework   xcode   1.0.0.1
               amtlib.framework   amtlib   6.0.0.75
               boost_date_time.framework   boost_date_time   6.0.0.0
               boost_signals.framework   boost_signals   6.0.0.0
               boost_system.framework   boost_system   6.0.0.0
               boost_threads.framework   boost_threads   6.0.0.0
               Cg.framework   NVIDIA Cg
               CIT.framework   CIT   2.1.0.20577   146758
               data_flow.framework   AdobeAIF   3.0.00   62.490293
               dvaaudiodevice.framework   dvaaudiodevice   6.0.0.0
               dvacore.framework   dvacore   6.0.0.0
               dvamarshal.framework   dvamarshal   6.0.0.0
               dvamediatypes.framework   dvamediatypes   6.0.0.0
               dvaplayer.framework   dvaplayer   6.0.0.0
               dvatransport.framework   dvatransport   6.0.0.0
               dvaunittesting.framework   dvaunittesting   6.0.0.0
               dynamiclink.framework   dynamiclink   6.0.0.0
               FileInfo.framework   FileInfo   66.145433   66.145433
               filter_graph.framework   AdobeAIF   3.0.00   62.490293
               hydra_filters.framework   AdobeAIF   3.0.00   62.490293
               ICUConverter.framework   ICUConverter   3.61   "gtlib_3.0" "." "16615"
               ICUData.framework   ICUData   3.61   "gtlib_3.0" "." "16615"
               image_compiler.framework   AdobeAIF   3.0.00   62.490293
               image_flow.framework   AdobeAIF   3.0.00   62.490293
               image_runtime.framework   AdobeAIF   3.0.00   62.490293
               LogSession.framework   LogSession   2.1.2.1681
               mediacoreif.framework   mediacoreif   6.0.0.0
               PlugPlug.framework   PlugPlug   3.0.0.383
               UpdaterNotifications.framework   UpdaterNotifications   6.0.0.24   "6.0.0.24"
               wrservices.framework
            Required plug-ins:
               3D Studio 13.0.6 x001  ©2006-2013 Adobe Systems Incorporated - from the file “U3D.plugin”
               Accented Edges 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Adaptive Wide Angle 13.0, Copyright © 2012 Adobe Systems Incorporated - from the file “Adaptive Wide Angle.plugin”
               Angled Strokes 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Average 13.0.6 x001  ©1993-2013 Adobe Systems Incorporated - from the file “Average.plugin”
               Bas Relief 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               BMP 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Camera Raw 9.1.1 (461), Copyright © 2015 Adobe Systems Incorporated - from the file “Camera Raw.plugin”
               Camera Raw Filter 9.1.1 (461), Copyright © 2015 Adobe Systems Incorporated - from the file “Camera Raw.plugin”
               Chalk & Charcoal 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Chrome 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Cineon 13.0.6 x001  ©2002-2013 Adobe Systems Incorporated - from the file “Cineon.plugin”
               Clouds 13.0.6 x001  ©1993-2013 Adobe Systems Incorporated - from the file “Clouds.plugin”
               Collada DAE 13.0.6 x001  ©2006-2013 Adobe Systems Incorporated - from the file “U3D.plugin”
               Color Halftone 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Colored Pencil 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               CompuServe GIF 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Conté Crayon 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Craquelure 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Crop and Straighten Photos 13.0.6 x001  ©2003-2013 Adobe Systems Incorporated - from the file “CropPhotosAuto.plugin”
               Crop and Straighten Photos Filter 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Crosshatch 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Crystallize 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Cutout 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Dark Strokes 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               De-Interlace 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Dicom 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “dicom.plugin”
               Difference Clouds 13.0.6 x001  ©1993-2013 Adobe Systems Incorporated - from the file “Clouds.plugin”
               Diffuse Glow 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Displace 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Dry Brush 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Eazel Acquire 13.0.6 x001  ©1997-2013 Adobe Systems Incorporated - from the file “EazelAcquire.plugin”
               Embed Watermark NO VERSION - from the file “DigiSign.plugin”
               Entropy 13.0.6 x001  ©2006-2013 Adobe Systems Incorporated - from the file “statistics.plugin”
               Extrude 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               FastCore Routines 13.0.6 x001  ©1990-2013 Adobe Systems Incorporated - from the file “FastCore.plugin”
               Fibers 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Film Grain 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Filter Gallery 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Flash 3D 13.0.6 x001  ©2006-2013 Adobe Systems Incorporated - from the file “U3D.plugin”
               Fresco 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Glass 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Glowing Edges 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Google Earth 4 KMZ 13.0.6 x001  ©2006-2013 Adobe Systems Incorporated - from the file “U3D.plugin”
               Graphic Pen 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Halftone Pattern 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               HDRMergeUI 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “HDRMergeUI.plugin”
               IFF Format 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Ink Outlines 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               JPEG 2000 13.0.6 x001  ©2001-2013 Adobe Systems Incorporated - from the file “JPEG2000.plugin”
               Kurtosis 13.0.6 x001  ©2006-2013 Adobe Systems Incorporated - from the file “statistics.plugin”
               Lens Blur 13.0, Copyright © 2002-2012 Adobe Systems Incorporated - from the file “Lens Blur.plugin”
               Lens Correction 13.0, Copyright © 2002-2012 Adobe Systems Incorporated - from the file “Lens Correct.plugin”
               Lens Flare 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Liquify 13.0, Copyright © 2001-2012 Adobe Systems Incorporated - from the file “Liquify.plugin”
               Matlab Operation 13.0.6 x001  ©1993-2013 Adobe Systems Incorporated - from the file “ChannelPort.plugin”
               Maximum 13.0.6 x001  ©2006-2013 Adobe Systems Incorporated - from the file “statistics.plugin”
               Mean 13.0.6 x001  ©2006-2013 Adobe Systems Incorporated - from the file “statistics.plugin”
               Measurement Core 13.0.6 x001  ©1993-2013 Adobe Systems Incorporated - from the file “MeasurementCore.plugin”
               Median 13.0.6 x001  ©2006-2013 Adobe Systems Incorporated - from the file “statistics.plugin”
               Mezzotint 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Minimum 13.0.6 x001  ©2006-2013 Adobe Systems Incorporated - from the file “statistics.plugin”
               MMXCore Routines 13.0.6 x001  ©1990-2013 Adobe Systems Incorporated - from the file “MMXCore.plugin”
               Mosaic Tiles 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Multiprocessor Support 13.0.6 x001  ©1990-2013 Adobe Systems Incorporated - from the file “MultiProcessor Support.plugin”
               Neon Glow 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Note Paper 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               NTSC Colors 13.0.6 x001  ©1993-2013 Adobe Systems Incorporated - from the file “NTSC Colors.plugin”
               Ocean Ripple 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Oil Paint 13.0, Copyright © 2011 Adobe Systems Incorporated - from the file “Oil Paint.plugin”
               OpenEXR 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Paint Daubs 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Palette Knife 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Patchwork 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Paths to Illustrator 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               PCX 13.0.6 x001  ©1989-2013 Adobe Systems Incorporated - from the file “PCX.plugin”
               Photocopy 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Photoshop 3D Engine 13.0.6 x001  ©2006-2013 Adobe Systems Incorporated - from the file “Photoshop3DEngine.plugin”
               Picture Package Filter 13.0.6 x001  ©1993-2013 Adobe Systems Incorporated - from the file “ChannelPort.plugin”
               Pinch 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Pixar 13.0.6 x001  ©1989-2013 Adobe Systems Incorporated - from the file “Pixar.plugin”
               Plaster 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Plastic Wrap 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               PNG 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Pointillize 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Polar Coordinates 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Portable Bit Map 13.0.6 x001  ©1989-2013 Adobe Systems Incorporated - from the file “PBM.plugin”
               Poster Edges 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Radial Blur 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Radiance 13.0.6 x001  ©2003-2013 Adobe Systems Incorporated - from the file “Radiance.plugin”
               Range 13.0.6 x001  ©2006-2013 Adobe Systems Incorporated - from the file “statistics.plugin”
               Read Watermark NO VERSION - from the file “DigiRead.plugin”
               Reticulation 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Ripple 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Rough Pastels 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Save for Web 13.0, Copyright © 1999-2012 Adobe Systems Incorporated - from the file “Save for Web.plugin”
               ScriptingSupport 13.0, Copyright © 2013 Adobe Systems Incorporated - from the file “ScriptingSupport.plugin”
               Shear 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Skewness 13.0.6 x001  ©2006-2013 Adobe Systems Incorporated - from the file “statistics.plugin”
               Smart Blur 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Smudge Stick 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Solarize 13.0.6 x001  ©1993-2013 Adobe Systems Incorporated - from the file “Solarize.plugin”
               Spatter 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Spherize 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Sponge 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Sprayed Strokes 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Stained Glass 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Stamp 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Standard Deviation 13.0.6 x001  ©2006-2013 Adobe Systems Incorporated - from the file “statistics.plugin”
               STL 13.0.6 x001  ©2006-2013 Adobe Systems Incorporated - from the file “U3D.plugin”
               Sumi-e 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Summation 13.0.6 x001  ©2006-2013 Adobe Systems Incorporated - from the file “statistics.plugin”
               Targa 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Texturizer 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Tiles 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Torn Edges 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Twirl 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Underpainting 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Vanishing Point 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “VanishingPoint.plugin”
               Variance 13.0.6 x001  ©2006-2013 Adobe Systems Incorporated - from the file “statistics.plugin”
               Water Paper 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Watercolor 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Wave 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Wavefront|OBJ 13.0.6 x001  ©2006-2013 Adobe Systems Incorporated - from the file “U3D.plugin”
               Wind 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Wireless Bitmap 13.0.6 x001  ©1989-2013 Adobe Systems Incorporated - from the file “WBMP.plugin”
               ZigZag 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
            Optional and third party plug-ins:
               WhiteWindowWorkaround 1.0.6, Copyright 2013-2014 - from the file “WhiteWindowWorkaround.plugin”
            Plug-ins that failed to load: NONE
            Flash:
               Mini Bridge
               Kuler
            Installed TWAIN devices: NONE
