Since the update to Version 20 the update is not working anymore. Has anyone had the same problems and was able to solve them?
AutoUpdateDisable=0
SilentAutoUpdateEnable=1
SilentAutoUpdateServerDomain=GBKGCMM01.company.internal
SilentAutoUpdateVerboseLogging=1
2015-12-7+6-38-47.848 [error] 1220 1078
=O====== M/19.0.0.245 2015-12-07+06-37-10.141 ========
0000 00000010 FlashPlayerInstaller.exe -install -iv 9
0001
0002
0003 00000011 1
0004 00000020 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0005
0006
0007 00000013
0008 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_19_0_0_245_ActiveX.exe
0009 00000016 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_19_0_0_245_ActiveX.dll
0010 00000023 C:\Windows\SysWOW64\Macromed\Flash\activex.vch
0011 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0012
0013
0014 00000021 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe
0015
0016 00000012
=X====== M/19.0.0.245 2015-12-07+06-38-48.004 ========
2015-12-7+6-38-48.316 [info] 1628 GBKGCMM01.company.internal
2015-12-7+6-38-48.316 [info] 1629 GBKGCMM01.company.internal
2015-12-7+6-38-48.316 [info] 1614
2015-12-7+6-38-48.316 [info] 1615
2015-12-7+6-38-48.316 [info] 1618
2015-12-7+6-38-48.331 [info] 1608
2015-12-7+6-38-48.331 [info] 1631 /pub/flashplayer/update/current/sau/currentmajor.xml
2015-12-7+6-38-48.378 [info] 1630 /pub/flashplayer/update/current/sau/19/xml/version.xml
2015-12-7+6-38-48.378 [info] 1632
2015-12-7+6-38-48.394 [info] 1632
2015-12-7+6-38-48.394 [info] 1630 /pub/flashplayer/update/current/sau/19/xml/patch.xml
2015-12-7+6-38-48.394 [warning] 1445
2015-12-7+6-38-48.394 [info] 1601
2015-12-7+6-38-50.844 [info] 1622 4
2015-12-7+6-38-51.515 [info] 1602
2015-12-7+6-38-51.515 [info] 1610
2015-12-7+6-38-51.515 [info] 1612
2015-12-7+6-38-51.515 [info] 1620
=O====== M/16.0.0.296 2015-12-07+06-38-54.075 ========
0000 00000010 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_16_0_0_296_Plugin.exe -uninstall plugin -msi
0001
0002
0003
0004
0005
0006
0007
0008
0009
0010
0011
0012
0013
0014
0015
0016
0017
0018
0019
0020
0021
0022
0023 00000011 1
0024 00000012
=X====== M/16.0.0.296 2015-12-07+06-38-54.325 ========
2015-12-7+6-40-20.669 [error] 1220 1078
=O====== M/19.0.0.245 2015-12-07+06-38-51.547 ========
0001
0002 00000011 1
0003 00000020 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0004
0005
0006
0007
0008
0009
0010
0011
0012
0013 00000014
0014 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_19_0_0_245_Plugin.exe
0015 00000024 C:\Windows\SysWOW64\Macromed\Flash\plugin.vch
0016 00000017 C:\Windows\SysWOW64\Macromed\Flash
0017 00000022 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerPlugin_19_0_0_245.exe
0018 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0019
0020
0021 00000021 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe
0022
0023 00000012
The Update to Version 19.0.0.245 works well but since that it doesn't work anymore.
=X====== M/19.0.0.245 2015-12-07+06-40-20.731 ========
2015-12-7+6-40-21.44 [info] 1628 GBKGCMM01.company.internal
2015-12-7+6-40-21.44 [info] 1629 GBKGCMM01.company.internal
2015-12-7+6-40-21.59 [info] 1614
2015-12-7+6-40-21.59 [info] 1615
2015-12-7+6-40-21.59 [info] 1618
2015-12-7+6-40-21.59 [info] 1608
2015-12-7+6-40-21.59 [info] 1631 /pub/flashplayer/update/current/sau/currentmajor.xml
2015-12-7+6-40-21.106 [info] 1630 /pub/flashplayer/update/current/sau/19/xml/version.xml
2015-12-7+6-40-21.122 [info] 1612
2015-12-7+6-40-21.122 [info] 1620
- HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Macromedia\FlashPlayerSAU\LastUpdateCheck
- HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Macromedia\FlashPlayerSAU\UpdateAttempts
and
- HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Macromedia\FlashPlayer\LastUpdateCheck
- HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Macromedia\FlashPlayer\UpdateAttempts
Then I have the following in the Log-File:
2015-12-16+8-9-51.635 [info] 1631 /pub/flashplayer/update/current/sau/currentmajor.xml
2015-12-16+8-9-52.618 [info] 1630 /pub/flashplayer/update/current/sau/19/xml/version.xml
2015-12-16+8-9-52.665 [info] 1612
2015-12-16+8-9-52.680 [info] 1620
So it never jumps to the Version 20
Here is the Content of the currentmajor.XML:
<version>
<Player major="20" majorBeta="20"/>
</Version>
Trying to access the currentmajor.XML via https ends up as expected. The Internet Explorer Shows me the Content as it is.
Any idea to fix this ?
hi,
Please post the contents of the /pub/flashplayer/update/current/sau/19/xml/version.xml file./
Thank you.
Maria
<?xml version="1.0"?>
<version>
<ActiveX major="19" minor="0" buildMajor="0" buildMinor="245"/>
<Plugin major="19" minor="0" buildMajor="0" buildMinor="245"/>
<Pepper major="19" minor="0" buildMajor="0" buildMinor="245"/>
<MacPlugin major="19" minor="0" buildMajor="0" buildMinor="245"/>
<MacPepper major="19" minor="0" buildMajor="0" buildMinor="245"/>
<SAUConfig checkFrequency="1"/>
</version>
Thanks for posting the contents. It points to the cause of why Background Update is not working. You need to update the version.xml file in this directory with the latest version 20 file. The service checks this file to find out what the latest version is and if it is higher than what is installed it updates, otherwise, it terminates as no new update is found. Seems you updated the currentmajor.xml file but not this file.
Please be sure to deploy the entire contents of the fp_background_update.cab file to your local server, overwriting what's there from a previous release, for Background Update to work correctly.
Maria
