21 Replies Latest reply on Dec 20, 2015 5:17 PM by barth34230974
    Installing ColdFusion on Windows 10
    BillDane_VA Level 1
      Anyone successfully installed CF11 (or any other version) on a Windows 10 machine?
      I installed IIS, ISAPI Extensions, ASP.NET, and CGI.  The CF11 installer seemed to run well, and got to the point where it would normally launch CF Admin and came up with a 404 error.  I ran the Web Server Configuration Tool, and it pops up a warning box that says "Version 10.0 installed. Supported versions are 4.x, 5.x, 6.x, 7.x, 8.x" after I chose all IIS sites. Also, there isn't a numbered folder under c:\ColdFusion11\config\wsconfig\ like there should be, so there are no Handler Mappings for CF file extensions in IIS.
      You'd think Adobe would be all over this as many developers will be switching to Windows 10 soon.
        • 1. Re: Installing ColdFusion on Windows 10
          haxtbh Level 4
          There is currently no support for Windows 10 / IIS 10. There is a bug report open about it here - Feature#3984812 - Support for IIS 10
          I can only assume there will be a hot fix coming soon with the changes required to get this working. Whether it will be before Windows 10 is released is anyones guess.
          • 2. Re: Installing ColdFusion on Windows 10
            JorgenSmith
            Confirmed, ColdFusion is *not* supported on Windows 10 / RTM / final release version.
            EDIT 2015-08-05: Adobe, can we have a status update please?
            • 3. Re: Installing ColdFusion on Windows 10
              Rohit S
              Need support for this asap. Already switched to Windows 10 and web server configuration tool is now broken.
              • 4. Re: Installing ColdFusion on Windows 10
                haxtbh Level 4
                I would recommend everyone direct all queries and requests to the bug that is open regarding this - Feature#3984812 - Support for IIS 10
                Stuff is more likely to get seen and updated that there.
                • 5. Re: Installing ColdFusion on Windows 10
                  Rohit S Level 1
                  In the meantime connector can be manually set, here's link to instructions (should work for CF11 as well): IIS manual connector configuration | ColdFusion 10
                  Create CFIDE and Jakarta Virtual Directories for each site on your IIS including default site (for CF admin site)
                  ColdFusion10 server connect to webserver through Connector Port, which is in server.xml. You can find this file in the {CF-HOME}\cfusion\runtime\conf directory.
                  In all the configuration below, replace {CF-HOME} with actual ColdFusion 10 installation directory. (For example, on UNIX,  /opt/ColdFusion10 and C:\ColdFusion10 for windows.)
                  • Extract the DLL from wsconfig.jar in {CF-HOME}\cfusion\runtime\lib.
                    • The IIS 64-bit DLL is in connector\isapi\intel-win64\prebuilt\amd64\isapi_redirect.dll
                    • The IIS 32-bit DLL is in connector\isapi\intel-win\prebuilt\isapi_redirect.dll
                    Create a folder in {CF-HOME}\config\wsconfig\{magic-number} and copy the DLL into that folder.
                    Create a file named isapi_redirect.properties and copy the content below into it.extension_uri = /jakarta/isapi_redirect.dll
                    log_file = {CF-HOME}\config\wsconfig\{magic-number}\isapi_redirect.log
                    log_level = info
                    worker_file = {CF-HOME}\config\wsconfig\{magic-number}\workers.properties
                    worker_mount_file = {CF-HOME}\config\wsconfig\{magic-number}\uriworkermap.properties
                    iis_buffer_enable =  true
                    Create uriworkermap.properties under {CF-HOME}\config\wsconfig\{magic-number} and copy the content below into it./cfformgateway/* = cfusion
                    /CFFormGateway/* = cfusion
                    /flex2gateway/* = cfusion
                    /flex2gateway = cfusion
                    /cffileservlet/* = cfusion
                    /CFFileServlet/* = cfusion
                    /cfform-internal/* = cfusion
                    /flashservices/gateway/* = cfusion
                    /flex-internal/* = cfusion
                    /rest/* = cfusion
                    /*.cfml/* = cfusion
                    /*.mxml = cfusion
                    /*.as = cfusion
                    /*.cfm = cfusion
                    /*.cfm/* = cfusion
                    /*.swc = cfusion
                    /*.cfml = cfusion
                    /*.cfc = cfusion
                    /*.cfc/* = cfusion
                    /*.cfr = cfusion
                    /*.cfswf = cfusion
                    /*.sws = cfusion
                    /*.jsp = cfusion
                    /*.hbmxml = cfusion
                    Create workers.properties under {CF-HOME}\config\wsconfig\{magic-number} and copy the content below. Make sure that the port mentioned is the same as the connector port mentioned for protocol "AJP/1.3" in server.xml.worker.list=cfusionworker.cfusion.type=ajp13
                    worker.cfusion.host=localhost
                    worker.cfusion.port=8012
                    worker.cfusion.max_reuse_connections=250
                    Double-click Handler Mappings, click Add Script Map in the Actions panel. Add handlers for cfm, cfc, cfml, cfr, and cfswf extensions and point all of them to {CF-HOME}\config\wsconfig\{magic-number}\isapi_redirect.dll.
                    Open IIS Manager, and select the website. Create the virtual directory CFIDE and jakarta.
                    • Virtual Directory name CFIDE location {CF-HOME}\cfusion\wwwroot\CFIDE.
                    • Virtual Directory name jakarta location {CF-HOME}\config\wsconfig\{magic-number}.
                    • Select the jakarta virtual directory in the Connections panel.
                    • Double-click the Handler Mappings icon in Feature View.
                    • Click Edit Feature Permission in the Actions panel.
                    • Ensure Execute is selected.
                    Double-click ISAPI Filters and click Add in the Actions panel. Give a Filter name (for example, Tomcat) and point it to {CF-HOME}\config\wsconfig\{magic-number}\isapi_redirect.dll.
                  Note:Enable the following features at IIS the level.
                  • ISAPI Extensions
                  • ISAPI Filters
                  • CGI
                  • ASP .NET
                  • 6. Re: Installing ColdFusion on Windows 10
                    haxtbh Level 4
                    On top of all that you will need to set index.cfm as the default document.
                    • 7. Re: Installing ColdFusion on Windows 10
                      solaced Level 1
                      I have tried it on Windows 10 and it doesn't work. The Web Server Configuration Tool simply doesn't see IIS 10 as a web server.
                      I've gone back to Windows 7 anyway - I find it much easier to use and navigate. Its actually quicker as well.
                      • 8. Re: Installing ColdFusion on Windows 10
                        Charles E. Brown Level 1
                        I have an even stranger problem. I did a clean install of Windows 10 and when I went to install ColdFusion 11 I got a message saying that the Akamai installer does not recognize my browser. I tried it in Firefox, Chrome and the new Microsoft Edge. Same message in all three browsers.
                        I am ready to give up on Adobe..period!!!
                        • 9. Re: Installing ColdFusion on Windows 10
                          Anit_Kumar Adobe Employee
                          Hi Charles,
                          Since, the download mechanism is now using Akamai, the downloading process has changed a bit. In case the Akamai downloader fails, please try the following steps:-
                          1. Go to http://www.adobe.com/cfusion/tdrc/index.cfm?product=coldfusion.
                          2. Complete your details on the right-hand side section, if not already.
                          3. Copy this link http://trials3.adobe.com/AdobeProducts/CSTD/11/win64/ColdFusion_11_WWEJ_win64.exe and paste it on the browser URL and hit “enter”.
                          The installer will start downloading. Let me know, in case it doesn’t work for you.
                          Anit Kumar
                          • 10. Re: Installing ColdFusion on Windows 10
                            Anit,
                            Many thanks for the information. It seems to be downloading. I just hope it works in Windows 10 after it loads.
                            The part that gets me is that Adobe has had nearly 2-years warning that this upgrade was coming, with nearly 6 months of a very public and stable beta of Windows 10. Nearly all other software I use made the conversion without a single problem. The only software to give me problems is Adobe.
                            Anyhow, once again, thank you for your assistance. It is much appreciated,
                            Charles
                            • 11. Re: Installing ColdFusion on Windows 10
                              bretg91927688
                              Seriously, never even considered that Adobe wouldn't support Windows 10 for Coldfusion.  Upgraded to Win10 and CF no workie.  Did clean install, no workie.  Akamai DM won't even work on Win10 (tried chrome and edge).  Very disappointing after 15 years of CF work.
                              • 12. Re: Installing ColdFusion on Windows 10
                                Fysicusje
                                I recently heard they'll be releasing a new version soon, perhaps they'll be waiting until then, assuming that most people will refrain trom upgrading to Windows 10?
                                • 13. Re: Installing ColdFusion on Windows 10
                                  doug777 Level 1
                                  When I follow these instructions, I find that I need to add IsapiModule to Modules before I can add Handler Mappings. But to add a Managed Module I need to choose or enter a Type. What should be entered here? If I choose something at random from the list and then try to access administrator, I get a Bad Module error, presumably because I've chosen the wrong Type.
                                  Doug
                                  • 14. Re: Installing ColdFusion on Windows 10
                                    woad Level 1
                                    I followed the above instructions, but I still get this error:
                                    My CF installation is a developer using server configuration...nothing fancy.  Any ideas?
                                    Eric Roberts
                                    Three Ravens Consulting
                                    Sr. ColdFusion Developer
                                    ps.  I just started a new contract and I really need to get my dev environment back up and running...so HELP!!!  Thanks in advance...
                                    HTTP Error 500.0 - Internal Server Error
                                    The page cannot be displayed because an internal server error has occurred.
                                    Most likely causes:
                                    • IIS received the request; however, an internal error occurred during the processing of the request. The root cause of this error depends on which module handles the request and what was happening in the worker process when this error occurred.
                                    • IIS was not able to access the web.config file for the Web site or application. This can occur if the NTFS permissions are set incorrectly.
                                    • IIS was not able to process configuration for the Web site or application.
                                    • The authenticated user does not have permission to use this DLL.
                                    • The request is mapped to a managed handler but the .NET Extensibility Feature is not installed.
                                    Things you can try:
                                    • Ensure that the NTFS permissions for the web.config file are correct and allow access to the Web server's machine account.
                                    • Check the event logs to see if any additional information was logged.
                                    • Verify the permissions for the DLL.
                                    • Install the .NET Extensibility feature if the request is mapped to a managed handler.
                                    • Create a tracing rule to track failed requests for this HTTP status code. For more information about creating a tracing rule for failed requests, click here.
                                    Detailed Error Information:
                                    Module   IsapiFilterModule
                                    Notification   AuthenticateRequest
                                    Handler   ExtensionlessUrlHandler-Integrated-4.0
                                    Error Code   0x80070001
                                    Requested URL   http://127.0.0.1:80/
                                    Physical Path   C:\inetpub\wwwroot
                                    Logon Method   Anonymous
                                    Logon User   Anonymous
                                    I
                                    • 15. Re: Installing ColdFusion on Windows 10
                                      Can you try to access CF Admin?
                                      Anit Kumar
                                      • 16. Re: Installing ColdFusion on Windows 10
                                        Curt Gratz Level 1
                                        Also, if you look at your IIS logs you might be able to see the entire error.  Also a good idea to check the CF logs.
                                        • 17. Re: Installing ColdFusion on Windows 10
                                          ThreeRavens
                                          When is this going to get this fixed?  Windows 10 has been available to get this right for a very long time.  Come Adobe...get off of your backsides and get this right.  This is really hurting the development community since Win 10 was an update provided via windows update rather than a regular install.  A lot of people upgraded and now cannot use CF locally for development.  The lack of a fix for this is very unprofessional and is symptomatic of why CF gets such a bad name.  IS Adobe just trying to kill CF?  At least let us know so we can move on to other languages.  This lack of action on this show stopper of a bug is not very fair to a very loyal developer community.
                                          Eric Roberts
                                          owner@threeravensconsulting.com
                                          • 18. Re: Installing ColdFusion on Windows 10
                                            haxtbh Level 4
                                            This has been fixed. The latest CF 10 / 11 update added Windows 10 / IIS 10 compatibility.
                                            ColdFusion 11 Update 7
                                            ColdFusion 10 Update 18
                                            1 person found this helpful
                                            • 19. Re: Installing ColdFusion on Windows 10
                                              Vospri
                                              Why has the latest installer not been updated, almost a month after the patch.
                                              Come on Adobe.. really..
                                              • 20. Re: Installing ColdFusion on Windows 10
                                                barth34230974
                                                I am having the same problem with CF11 on Windows 10, it hasn't installed correctly and the Update 7 solution is hardly helpful when it tells you to get the update through the CFAdmin page. How can I do that if CF won't run?
                                                Where can I get Update 7 download?
                                                It's very frustrating how for a long time now, CF installers on Windows/IIS always seem to have problems.  I remember back when they just worked
                                                • 21. Re: Installing ColdFusion on Windows 10
                                                  barth34230974 Level 1
                                                  Ok, please disregard previous post, I found the update download page and installed it, ran the webserver connector tool and all is working now.
