Hello,
My new webcam Microsoft Livecam Studio works perfectly with all programms. But if I start presenter- video express 11 I get the message: "Your webcam is busy or it is not functioning. Try closing other application that might be using the webcam and select it again."
But there is no application using the webcam, no programm is working .
I later can record a video with the webcam and video express and the project even shows the presentation and I can use all the features to edit, but not at the very beginning ( for instance to select my face before recording.)
Any hint?
Thanks in Advance
Sorry to hear that you are facing issue.
To analyze the issue, I will request you to launch PVX in diagnostic mode and collect the logs when you close the app. Send us the logs here.
We will soon get back to you with a solution.
Soumodipto Chatterjee
Presenter Engineering Team
Adobe
Hello,
I did that already but I don't know where to find the file. What will be the name of the file?
Greetings and thanks in advance
Andreas
Sorry again. I found the file: Named DiagLogs756414465925. Its a zip file
How do I send it to you?
Launch the app in diagnostic mode, try recording in PVX.
Do a recording. Once the recording the recording is done. Close the app. While closing the app you will get a dialog box for saving the logs. Select a locations where you want to save the logs.
The file will be in a .zip format.
Send me those files to analyze it further.
Adobe
Hello,
as a told you I have the zip-file but no email adress.
I tried to send it to PVX-ProductionSupport@adobe.com but it was rejected because of no authorization
If you are so kind to give me a valid mail-address.
Tnak you very much
Hello Soumodipto,
please can you forward me a mail-adress wher to send the file or another posssibility to send it.
Thanks in advance
Andreas Overbeck
Hi Andreas,
I got the attachment. There I found that you are using Microsoft Lifecam. But there are 2 drivers installed for the Microsoft Lifecam with different versions. So kindly if you check that a single driver is installed for your webcam.
To get a proper driver installed, go to device manager, look for webcam. Uninstall the drivers from there for your webcam. Then you can scan for drivers, and the new drivers for the webcam will get installed. You can use any other ways to do this.
Once you do this, let me know if you are facing any issues. I have dropped an mail from my personal mail id.
Adobe
Hi Soumodipto,
I did what you told me. Now the name of the new driver is different.
But the problem persists.
Shall I do a new attempt with diagnostic mode?
Greetings Andreas
Hi Andreas,
Yes. Kindly if you can send me the logs with the diagnostic mode on.
Adobe
It´s really terrific all the work you are doing.
I just send th file to the mail adress you gave me.
Looking forward
Greetings
Andreas
Can you send the files through dropbox or any other way as the mail has not yet delivered.
Adobe
I've sent you a ling to share the Dropbpx to the mail-adress you gave me: sochatte@adobe.com
Greetings
All it seems now is that your webcam is being used by some other background app which is running in your system. The app can be some camera app, some messenger app, skype etc.
Try to kill the process which you think can use your camera and then check PVX.
Adobe
I start the computer and do not use any programm. I just directly start PVX and the message appears. And it is only PVX which "complaints". Furthermore later I can record with the camera which shouldn't be possible if the camara is used.
The message makes no sense, sorry, and it is a specific problem of PVX and the Livecam, other cameras work (but I don't use them because of the lower resolution).
If it was a systemic use of the camera this will happen also with others, but it doesn't happen
Greetings
Hi again,
I looked into the administrator and did a screenshot. No other apllication is using the camera. You may find the screenshot int the dropbox-folder. Very strange
