As you probably know, the core JS files for Responsive HTML5 output are minified (rh.min.js, common.min.js, layout.min.js, topic.min.js etc.). Do you think there's any chance that Adobe will distribute the original versions of these files? This would greatly increase the options for experienced users and web developers to customize and optimize the HTML5 output for the individual customer's needs.
I know opening up source code is a difficult issue, but as the JS files are still highly dependent on the (closed source) RoboHelp application, I think the opportunities by far outweigh the risks.
And it's available.
https://helpx.adobe.com/robohelp/robohelp-screen-profiles-layouts.html
Abhishek
I have brought this post to Adobe's attention.
Great, thank you Peter.
Adobe may be reluctant to post the source code since they maintain it and may update it in any given patch. It's not so much an issue with the code being used by competitors (I think) as that if people make manual modifications, they will be lost whenever you install a patch.
What are you trying to achieve? You can add your own JavaScript extensions quite easily and also use the Angularesque structure of the HTML and the JavaScript to manipulate the layout. If you can tell a bit about what you want to do, I may be able to point you in the right direction. You can hook into the system rather easily but the documentation is somewhat lacking at the moment.
I think people who are experienced enough to modify the JS core files will be able to deal with breaking changes through updates. They will know that it's part of the deal. If they prefer consistency, they can stick to the original files and avoid the core files. But right now, we don't even have a choice. Choice is always better 🙂
I know there's already a lot you can do with own JS extensions and stuff like that. Actually, I already managed to modiy the HTML5 output quite heavily. For example, I replaced the dynamic content filter list by a select box based on the select2 project (Select2 - The jQuery replacement for select boxes). It's looking great and it works, however, it feels more like a hack right now. I wasn't able to fetch the events are raised when the filter list is built completely or when the user clicks on a filter entry - all that is minified in the core files. Instead, I had to install a mutation observer that goes like: "Oh, apparently the right thing happened within the DOM, let's go". Providing the JS core files would allow me to code this in a much more professional and reliable way.
We are in process of making these files available.
Thanks for your patience.
Abhishek
Product Manager
Adobe Technical Communication Products
And it's available.
Abhishek
Wonderful! Thank you!
Could you please provide the latest JS files for RH 2017? Thank you!
I have drawn Adobe's attention to this request. If no response, you will
need to go to Tech Support.
