It sounds like you are talking merged webhelp here. It also
sounds like you might be maintaining your projects on a network
drive as you refer to the ex-employee having a local copy. Unless
you are using source control, projects should be local.
When you took over, you would either have had to copy all the
projects across or check them out of source control. If that is the
way you work, I would guess your predecessor did the same so the
project is there somewhere. I maintain the glossary in the parent.
Is that the setup?
