A really weird event just happened. I found that Foxfire had disabled my Flash Player 19,
stating that it was out of date and dangerous.
So I went to the Adobe site and downloaded the install for the latest version, the file name
is flashplayer20_a_install.exe with a file size of 1.163 MB.
But when I double-click the file, nothing happens. I expected to have the popup with the
query to Run the file, but got nothing. I opened the Windows Task Manager and saw no
listing in the 'Applications' tab for the install routine, which means it's not running.
I thought maybe the presence of FP19 might be a problem, so I uninstalled it. Still could
not run the FP20 install. So I deleted the install program, downloaded it from another website,
and this program was named flashplayer20_ha_install.exe. Before running it, I restarted my
computer to reinitialize everything. I double-clicked it and again got nothing.
In rummaging thru my Downloads folder, I found an old install program for FP 16. I clicked
on it and was able to install Flash Player 16. By the way, the file size for this install program
was 17.7 MB, which is 17 times as big as the install programs for FP20. With FP16 still
present, I again tried to install FP20 with the same futile results.
So these current install programs seem Suspect. Can anyone shed any light on what's going on?
so adobe uses stub installers, which means that it is a small program that goes out and gets the program. The reason for this is because of the download page; that page contains an optional McAfee installer, that is the reason they use the stubs this way it allows them to bundle that extra bloatware.
There are a couple options for you to do:
1) Preform a fully manual uninstall and re-install kind of a pain.
2) A clean install if things do not seem to work, even more of a pain.
3) Use a scripted unin
...Copy link to clipboard
3) Use a scripted uninstall, clean up, and re-install
To do the uninstall you need to get the uninstall file here:
http://download.macromedia.com/get/flashplayer/current/support/uninstall_flash_player.exe
Right click, and run as administrator
Next you will need the two files 1 is for Internet explorer flash and the other is for your Firefox Flash Player
Right Click, and Run as administrator
If these files are not running for some reason, try a reboot and run them, if they are still not running then you could have something wrong with your system, you Antivirus preventing it, or a piece of malware or virus.
IF the manual install does not work try going here: Adobe Flash Updater - Browse /BAT version at SourceForge.net
get the downloadFlash_XPandUP.cmd file. ( you can right click and edit to see contents. Basically this file will do the uninstall, and clean install of your plash player versions for you. Once again right click and run as administrator.
Judging by the fact that you were able to install the older flash player; which is the actual reall install not the stub seems to indicate something is blocking the stub programs to run.
Hopefully that gives you some direction
Best regards
Hi leeb86385142,
This may happen because of a certificate issue. The installer uses the SHA256 certificate, which may not be compatible with a computer that is running Windows Vista SP2.
If this is your setup, head over to the Microsoft Support page to download an update for your operating system.
Maria
Thank you Maria. I do believe I am using SP2, so that may be why it won't install.
I was able to update FP16 to FP20 by using the Adobe Flash Updater - Browse /BAT version at SourceForge.net
as suggested by Carm01.
