Hi, I'm trying to figure out how to create an account connect pro server.
Basically I am considering Presenter 11 before buying it and I feel packets export. It seems that the program exports only account SCORM Connect Pro Server.
How do I proceed.
Thank you
It has three publishing options: locally to your computer, directly to an Adobe Connect server or locally as a PDF. If you are not looking to publish to a Connect server, then you will need to publish locally (probably as a zip to make things simple) and then upload that zip to your desired server.
As to supported reporting standards: Adobe Presenter 11 - Features
Thank you for the comprehensive answer,
taking advantage of the kindness I want to ask another question.
I tried all three options, locally and export but Moodle does not recognize the zip as SCORM.
How should I proceed?
Thanks for your patience and availability.
Did you configure your SCORM settings in the Quiz Manager? It should be located under Quiz Manager > Reporting tab. Presenter Help | Adding quizzes and questions
If that is configured, you may want to test it using SCORM Cloud: Scorm Cloud Testing Content with SCORM Cloud » SCORM - and see if that reveals any configuration issues.
Tutto risolto.
Grazie infinite.
Saluti, Claudio
