After apache upgrade on our production servers we have reported the connection failure error in scheduled task on coldfusion.
Look like coldfusion is not getting response back from apache(web server)
"Information","scheduler-1","12/15/15","09:48:00",,"[File Assignment] Executing at Tue Dec 15 09:48:00 PST 2015"
"Information","scheduler-1","12/15/15","09:48:00",,"Error while executing task Connection Failure: Status code unavailable"
"Information","scheduler-1","12/15/15","09:48:00",,"Connection Failure: Status code unavailable"
"Information","scheduler-1","12/15/15","09:48:00",,"[File Assignment] Rescheduling for :Tue Dec 15 09:50:00 PST 2015 Now: Tue Dec 15 09:48:00 PST 2015"
Operating system :- Windows server 2008 R2
Coldfusion version : 9.0.1.274733
Old Apache Version – 2.2.15 with openssl 0.9.8g
Upgraded Apache version – 2.2.31 with openssl 1.0.1p.
Please help
Have you removed and reinstalled the connectors between ColdFusion and Apache?
Thanks Carl.
I haven't tried it..
Can you please provide me the steps how to remove and reinstall connectors?
We are using coldfusion 9.
Shajin C
Run the Web Server Connector tool (as Administrator) and remove the connection(s) to Apache. Close the tool and relaunch it again (as Administrator) and then reconnect to Apache.
-Carl V.
Thanks for your reply.
We don't have any web server connector tool ..
cacert and Jrun mod used to communicate to apache.
just wanted to add here only we have issue with scheduled tasks ..
-Shajin C
added to above comment ..I just tried removing the apache and added back using connector tool( wsconfig.exe) but still seeing the same error.
I believe it's the same way what you are talking here.
please let me know if you can help
-Shajin C
Is this a https request? Do you use custom certificates?
If it's an https request, you may need to add the cert to java keystore.
Sumit Verma
Partner / Vice President | ten24, LLC
office: 877.886.5806 x 103 | mobile: 617.290.8214
www.ten24web.com | www.linkedin.com/in/sverma | twitter: blogonria
