Hi again
There is one thing I stress in all the classes I conduct. You
never ever want to confuse your source with your output.
The files in one location are the source files. Files in the
!SSL! location are the OUTPUT files. If the folder isn't showing in
your RoboHelp Project manager, you are probably safe to delete it
manually using Windows Explorer, because RoboHelp will only list
what it knows about inside the Project Manager.
However, just to be on the totally safe side, I would suggest
moving the folder to a different area until you are absolutely
certain it (and nothing inside it) is needed. Once you are certain,
then delete it for good.
You will also likely find some folders inside that !SSL!
folder that don't exist in your source folder. These will have
names like WHDATA, WGDATA, etc. They are there for supporting
WebHelp.
Cheers... Rick
