I have problem to open my purchased books (from konobooks, ebookmall, etc) after a disk crash & reinstalling of ADE. Please sent me a e-mail to tell you more detail about the problem
Dec 29, 2015 Dec 29, 2015
Dear Sir or Madam
I ' ve purchased a lot of e-books from a number of suppliers (Ebookmall, cobobooks, etc), like the one attached. All these were readable through the services of Adobe Digital Editions(pdf & epub format).Unfortunately I had a disk crash in summer & I retrieved many of my archives, including the e-books , which i' ve purchached, through data recovery. After that I have try to open the above book through ADE 4.5 but it appeared a message like the one attached.Exactly the same message appears in all efforts to open similar e-books like the one attached.In the same time I' ve use my lap-top to open my e-books , using ADE 3.0. Regarding this process , the ADE system requires authorisation & after that , it began to load the book. However , even after the competion of the loading bar, the systen is not able to load the book.
As i 've spent a lot of money for these books, all the time using the good services of Adobe Digital Editions, I like to have, please , a solution regarding my problems. I can't attach the ebook-sample. Furthemore i can't authorize my Deckstop ADE , because the system tells thai I use the same e-mail & password in other devise (my laptop)
Yours Faithfully
Spanos Christos
549
LEGEND , Dec 29, 2015 Dec 29, 2015
Macintosh:
  1. Open Adobe Digital Wditions.
  2. Press Command+Shift+D to deauthorize Adobe Digital Editions.
  3. Select Erase Authorization.
  4. Click OK and quit Adobe Digital Editions.
  5. Navigate to /Users//Library/Application Support/Adobe/Digital Editions and drag the activation.dat file to the trash.
    If you are using 10.7, see Access hidden library files | Mac OS 10.7 and later.
  6. Open Adobe Digital Editions and reauthorize.
Windows:
  1. Close all applications.
  2. Choose Start > Run.
  3. In the Open text box, type regedit and then
Macintosh:
Windows:
  3. In the Open text box, type regedit and then press Enter. The Registry Editor opens.
  4. In the left pane of the Registry Editor, locate the following registry key: HKEY_CURRENT_USER\Software\Adobe\Adept
  5. Select the Adept key.
  6. Choose File > Export.
  7. In the Export Registry File dialog box, select Selected Branch under Export Range. Enter a name and location for the backup registry key, and then click Save.
  8. Right-click the Adept key and choose Delete.
  9. In the Confirm Key Delete dialog, click OK.
  10. Close the Registry Editor.
  11. Open Adobe Digital Editions and reauthorize.
Jan 03, 2016 Jan 03, 2016
I have apply all these actions & authorize the ADE but still I can't open my purchased e-books
Christos
Has you open the eBook before you authorize right?
Jan 07, 2016 Jan 07, 2016
I had open my e-books, only before my disc crah and data recovery. After this I cant't open my e-books , even after reinstalling & re-authorizing my ADE 3.0 (Windows 7, Ultimate Editions). I have the same problem with all my purchased books (about 30-40) from various suppliers (Kobooks, ebokmal e.t.c.) Books freely downloaded from internet are capable to open, via ADE.
Christos
Has you used the same Adobe ID as on the old hard disc?
Jan 09, 2016 Jan 09, 2016
As far as remember I have used the same ID, for sure the same e-mail & the same name & surname. Can you make a check from your database?
Christos
Jan 10, 2016 Jan 10, 2016
NO Staff Person, only a Person how try to help. If you not sure which adobe id you used contact the reseller of the eBooks he can check the authorize.
Jan 11, 2016 Jan 11, 2016
I am quite sure that I have use the same Adobe ID
Christos
Then contact the reseller of the eBooks he can check the authorize.
