We have created a program that calls the Flash player.
Flash Player version is 20.0.0.267 in Windows 7
This version of the Flash Player 20.0.0.270 As the problem is we are running the program under Windows 7 is not solved.
But Windows 8 and this version is still in Flash Player 10 in Windows 20.0.0.267.
So this version of the flash player has the same problem occurs in Windows 7 and caused problems at 20.0.0.267.
When will wonder whether Windows 8 and Windows 10 update your flash player version, and in the hope it is hoping to soon.
Sorry, I'm not quite following your post. Version 20.0.0.270 (ActiveX Control for IE only) addresses a problem with Flash Player improperly loading applications that have Flash Player embedded. At this time, 20.0.0.270 is only available for Windows XP through Windows 7. We are working with Microsoft on the release for Windows 8 and above. If your issue is different from this issue please file a bug at https://bugbase.adobe.com/‌ and include as much information as possible (including OS, browser, and sample code if possible) in your bug record.
Maria
All sounds are launched in the loading. Embedded flash .swf buttons doesn't seem to be working properly neither. It is like AS3 is not working somehow. Application run perfectly in previous flash versions with Windows 7.
Thank you, Jose
Hi, have you verified with the latest FP 20.0.0.270 on win 7 /20.0.0.272 on win 10
Thanks, I tried 20.0.0.274 (verified through Adobe - Flash Player) in Firefox with Windows 7, still not running....
Could you please share swf and all steps to reproduce the issue.
Can you rename this thread more appropriately? Something like:
Of course:
http://www.musicaendo.com/opciones/peliculas/flauta44.swf
Hope you find a solution.
Thanks, Jose
Hello!
I have shared the .swf and still no solution at all!
Is there any progress?
Good Morning!
Should I have to be ok with it? Still not working... Last Firefox Flash update is being a nightmare for embedded swf applications this last two-three weeks. We need a solution as soon as possible please!!
Thanks, Jose
we just released a new version of Flash Player today. If you're system is configured for background updates it may have already installed. If not, please go to https://get.adobe.com/flashplayer to download and install the update.
The latest versions for supported operating systems/browsers is listed here: http://www.adobe.com/software/flash/about/‌
Maria
Good Morning:
True. Everything seem to work properly now. Thanks, Jose.
