what should I do when a pop up tells met "error! Check activation?"
Jan 09, 2016 Jan 09, 2016
‌a pop up tells me to check my activation. My laptop is already authorised. What should I do?
268
What program are you using?
Jan 10, 2016 Jan 10, 2016
I'm using ADE 4.5
  Windows:
  1. Close all applications.
  2. Choose Start > Run.
  3. In the Open text box, type regedit and then press Enter. The Registry Editor opens.
  4. In the left pane of the Registry Editor, locate the following registry key: HKEY_CURRENT_USER\Software\Adobe\Adept
  5. Select the Adept key.
  6. Choose File > Export.
  7. In the Export Registry File dialog box, select Selected Branch under Export Range. Enter a name and location for the backup registry key, and then click Save.
  8. Right-click the Adept key and choose Delete.
  9. In the Confirm Key Delete dialog, click OK.
  10. Close the Registry Editor.
  11. Open Adobe Digital Editions and reauthorize.
    Macintosh:
  12. quit Adobe Digital Editions.
  13. Navigate to /Users//Library/Application Support/Adobe/Digital Editions and drag the activation.dat file to the trash.
    If you are using 10.7, see Access hidden library files | Mac OS 10.7 and later.
  14. Open Adobe Digital Editions and reauthorize
Jan 11, 2016 Jan 11, 2016
Thanks for your reply. But there's still a problem.
According to step 6 I should select "Export". But there are only two choices I can make: Activation and Device.
You have any idea?
Kind regards,
Derk Jan
Origineel Bericht----
Van : forums_noreply@adobe.com
Datum : 11/01/2016 09:20
Aan : d.j.janse@hetnet.nl
Onderwerp : what should I do when a pop up tells met "error! Check activation?"
Nanaky created the discussion
"what should I do when a pop up tells met "error! Check activation?""
To view the discussion, visit: https://forums.adobe.com/message/8377476#8377476
Export the complete Folder Adept Folder.
