Hi
I am using RH11.0.4 and publishing my course for mobile using PhoneGap Build. This is a mobile-only course. So I am not too bothered about how it behaves on desktop.
Though I have a Welcome page, I want my users to start with ToC. So, I set the Output Folder and Start Page settings to table_of_contents.htm instead of the default index.html. Since PhoneGapBuild won't publish the android app without index,html, I copied that file from older published version of the same course and published the app.
However, when I load it on my mobile, it still starts with the Welcome page and not ToC. Please suggest a workaround.
Sreekanth
Hi Sreekanth,
If you want table_of_contents.htm to be your landing page, then you can choose that to be your Default topic. When you generate Responsive HTML5 output, the start page(index.html) is only the layout.
Default topic is what user sees on their mobile. Keep the Output folder and Start Page settings to be the index.html (that way PhoneGap won't mind ) and just set the Default topic to be table_of_contents.htm
Edit Responsive HTML5 Settings > Goto Content Page > Select the Appropriate Default topic.
I have included a screenshot of how to change the default topic for your convenience:
Also I will suggest, you give a try to the Mobile App publishing capability from Robohelp 2015 itself. You won't have to manually go and build the App from PhoneGap site.
Create Mobile Apps using Adobe RoboHelp 2015 – TechComm Central by Adobe
Hi Ritukumar
I have tried to set the table_of_contents.htm as Default Topic. But it won't show up when I click Select and browse for it.
Sreekanth
Is the table_of_contents.htm a topic in your project ?
No. It is the list of topics. In other words, it is the standard table of contents that appears on the right pane in the published output.
Sreekanth
Which layout are you currently using?
Willam, I am using the Theme1_Updated layout you have shared on your blog . I did not want the Search option as well. So tweaked that a bit.
Sreekanth
In the Screen Layout, select the Table_of_Contents.slp as the default page. (Expand the layout and right click the .slp). If you don't use CSH, that should open up the TOC.
Thanks Willam.
That got me the ToC as default page. However, when I first launch it, I get 2 header panels and 2 navigation panels at the bottom. Once I access some topic and go back to ToC, it gets right. Any idea why?
Here is a screenshot.
Sreekanth
I get that with Theme1 Standard, too. I think it's a "feature".
Willam might be able to suggest a fix, and the bug report form is here: https://bugbase.adobe.com/index.cfm
This definitely is a bug. I have only seen this behaviour before when the help was loaded in an iframe. Are you simply opening the browser or are you calling the help in a frame?
I get it when using right-click > View With > Internet Explorer (9) or Chrome (47).
RH 11.0.4.291
When I view it in desktop mode, the ToC shows up in the Content pane first. Same is happening when we open it in mobile view.
Willam, I know you play a lot around css and js files. And, I think you have some solution ready for this (or similar issue). I am searching the forum and will check your website as well. But if you have it handy, please share.
Sreekanth
While I appreciate the sentiment, I don't have a script lying around. The best way to work around this issue is by opening the Table_of_Contents.htm file directly. If you do it that way, it works as you'd expect. In RoboHelp 2015 this issue is solved.
Hi William
I now have RH 2015. But I still cannot find Table_of_contents.html to set it as Default Topic. Am I interpreting your reply incorrectly?
Sreekanth
Hi Shreekanth,
I'm not sure what I was referring to at that time. But you can set the TOC to be open/focussed oby default.
Hi Willam
I am using your Theme1_Updated (non-ToC) layout file. I did not find the usersettings.js in that.
I made the changes you suggested in the usersettings.js of the sample project, EmployeeCare3. It almost works. I mean, it flashes the ToC for a fraction of a second, but ends with the html page set as Default topic when I launch the index.html.
Btw, rh.model.publish(rh.consts('KEY_DEFAULT_TAB'), defaultPane); is on line number is 31 and not 35 as you mentioned.
Sreekanth
Hi Shreekant,
The instructions are for the Azure_Blue and Charcoal_Gray skins. No need to use the Theme1 layout. (Though you can import those and set the default page.)
I used the Theme1 layout as I wanted only the ToC (no search, glossary, and index.). But no luck so far.
Sreekanth
Try the new Azure_Blue! You have settings to disable the Index and Glossary 🙂 No coding required!
But it has Search. I tried to remove that and now the topics are now showing up in ToC. I will continue to work on that part. 😞
In any case, the ToC (without its topics) is still flashing before returning to the Default Topic page.
Sreekanth
Search cannot be disabled through the editor. Do you want to get rid of that? Removing search is more of an operation as a lot of options depend on the option being there. If you are up to getting your hands dirty, you can try the SCSS files 😉
For desktop, you can choose to display search results in the topic contents. (Search (All) component) That moves them out of the sidebar.
I managed to remove the search (or at least I think so for now). But I am still getting the error of ToC just flashing before I see the default topic.
Sreekanth
