Hi All,
I just got Lightroom CC, however when I try to work on the Tone curve in RGB it doesn't give me options to change it from Grayscale.
In all the online videos there is a drop down that allows you to select RGB. I don't have that drop down. Please help.
I discovered the problem. I had to update the images in the catalogue. They weren't processed under the newest version, so it wasn't giving me the editing options / features. Under Settings - Process - 2012.
That seemed to work.
Thanks for you input and help.
Regards
L
Hi lescas,
The option to edit grays is in the Bottom left corner "Target Group".
Akash
Hi Akash,
I do not have the Target Group underneath my image. How do I get it to display?
Regards
Lesca
As you can see on my screen shot. I don't have the RGB channel drop down under my tone curve. So I can only adjust grayscale.
I am not sure how to make this drop down accessible.
You don't get the drop down unless you are in Point Curve mode. Press the button that the arrow points to:
Hal
Regards
L
how did you do that ?
Presuming you mean "Process Version"!
A photo with a previous 'Process Version' will be indicated by a "lightning bolt" icon under the Histogram.
Click the icon the update to the Current Process Version.
Or- You can click on the Process Version Drop0down menu in the Calibration Panel and choose from the Process Version Menu-
Most of this forum thread is about the RGB Channels in the Tone Curve.
See Post#6 above by Hal for the icon that will show Tone Curve RGB Channels.
Fantastic - so helpful. Thanks ever so much for this.
I am running the current proces version (5 the time of writing) and still do not have access to RGB channels. Meep! Help!
I do not have it either. I do not have the box in the right hand corner to get it so the solutions are not helping me.
Did you figure it out? It's so frustrating.. I have tried all of the suggestions and none have worked for me.
