2
Adobe Digital Editions 4.5 Silent Install
Guest
Oct 12, 2015 Oct 12, 2015
Dear support,
I try to deploy ADE 4.5 silently with the following command but a window popup comes up and ask me if I want to include Norton Security: ADE_4.5_Installer.exe /s
I red on this post a solution that seems not working anymore:
Re: Adobe Digital Editions 4.0.3 mass install...
It says to add some reg keys before running the install silently.
In my case, I still get the popup window so I can't use this method to mass deploy this update.
Do you have another switch command or reg keys to avoid this behaviour please?
Thank you in advance,
Download
31.3K
New Here , Feb 22, 2016 Feb 22, 2016
Excerpt from this page:
IT Pro Tips for Adobe Digital Editions 4 | ITNinja
Disable Norton Security prompt
The installer searches for certain antivirus products, and if a qualifying product is not found it prompts to install Norton Security. To suppress this prompt, add the following registry key before the installer is executed:
Windows Registry Editor Version 5.00
; 32-bit OS [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\N360]
; 64-bit OS [HKEY_LOCAL_MACHINE\SOFTWARE\WO
Hi Josué,
I Added NSS=2 to the commandline
"ADE_4.5_Installer.exe /s NSS=2"  and it will install without Norton Security Scan
Thanks to IT Pro Tips for Adobe Digital Editions 4 | ITNinja for giving me the registry hint.
Kind regards,
Ivo
Guest
Oct 13, 2015 Oct 13, 2015
Hi IvoD,
Thank you for your solution. Unfortunately, on my side, I still get the Norton window popup even with the NSS=2 parameter.
Guest
Oct 27, 2015 Oct 27, 2015
This will only work if you have previously declined the installation of Norton or set the registry key values from that link you posted.  You can try this yourself, install ADE and decline Norton, remove ADE and then re-install and you won't get prompted to install Norton.  If you check the registry you can see that the registry key to decline Norton has been set by the first installation.
Guest
Oct 28, 2015 Oct 28, 2015
Hi there,
Thank you for your post.
I added this before the setup and it works on my test machine where I installed/uninstalled the product for testing:
reg add "HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Symantec\NPInstaller\DeclineCount\adobeebook" /v nss /t REG_DWORD /d 2 /f
But When I tried on my Golder Master Image it stopped with the Norton window popup...
Nov 20, 2015 Nov 20, 2015
Hey, if your master image is 32-bit, then you might need to use the 32-bit version of that registry key instead:
HKEY_LOCAL_MACHINE\SOFTWARE\Symantec\NPInstaller\DeclineCount\adobeebook
Ie. without the Wow6432Node part. That could be why it worked on your test machine, but not on your master image. Though I have only tried on 64-bit Windows so far so I haven't tested on 32-bit OS.
Edit: After testing a bit more, it turns out the installer also randomly uses different values for nss and nis, and no combination I've tried yet will work on our unattended software deployment without popping up the Norton Internet Security dialog.
Guest
Dec 04, 2015 Dec 04, 2015
Hello,
I'm using Windows 64 Bit OS only.
Jan 11, 2016 Jan 11, 2016
I found /s NSS=0 actually works.
Jan 12, 2016 Jan 12, 2016
For me /s NSS=0 not work and no other solution work.
I need a solution please because I have about 80 computer.
Wath program do you use to deploy Adobe Digital Solution using /s NSS=0 switch?
Jan 13, 2016 Jan 13, 2016
I ended up writing a script to set that reg key and then installing the app with just /s (nss= doesn't seem to do anything), and that worked. I'm managing about 6200 clients?
I'm using System Center 2012 Configuration Manager (on 2012 R2 SP1 CU1 with a bunch of hotfixes).
Feb 10, 2016 Feb 10, 2016
I hope adobe will solve this problem as soon as possible.
Please give us a solution.
Feb 14, 2016 Feb 14, 2016
If you want I can share my powershell script I wrote to handle all its problems/shortcomings? Let me know - I'll do it when I get into work tomorrow.
Feb 16, 2016 Feb 16, 2016
Please share your powershell script.
Here you go:
Package Exports
I do assume its 64 bit windows. If you have 32 bit machines - its using the powershell app deployment framework. I guess you can let me know and I can help, or you can download and read the variable reference here:
Releases · PSAppDeployToolkit/PSAppDeployToolkit · GitHub
Here's what I've found.  If I try to install interactively with an admin account, I can use this before running the installer:
reg.exe add "HKEY_LOCAL_MACHINE\SOFTWARE\Symantec\NPInstaller\DeclineCount\adobeebook" /v "nss" /t REG_DWORD /d 2 /f /reg:32
However, once it comes time to deploy it to hundreds of systems, obviously it is going to be through a management system like SCCM or KACE.  In my case, I then tried it with KACE and found it was still coming up with the Norton scanner dialog.  I found that when running it that way, the installer instead sets a value of NIS to 1, instead of NSS to 2.  So, fine, I added another reg.exe add line to also add NIS=1.  However, it still wouldn't work.  I then put timeout.exe /t 30 in between setting the registry and executing the installer to make sure the registry values were being set.  On the test system, I had the regedit open and I kept refreshing until I indeed saw those two values set... however, the Norton dialog still came up.  I switched over to regedit and found that those values were DELETED once the installer ran thus why the Norton dialog was still coming up.
So, for those who say they have it working in SCCM and/or KACE, I really don't believe you at this point, as I don't know why it would be deleting those registry values just on my test system.
; 64-bit OS [HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\Microsoft\Windows\CurrentVersion\Uninstall\N360]
Note: The nis and nss registry values mentioned in other tips are not required.
Works for me.
Jan 25, 2019 Jan 25, 2019
rem prevent norton prompt, happens after three no clicks
reg add HKLM\SOFTWARE\WOW6432Node\Symantec\NPInstaller\DeclineCount\adobeebook /f /v ns  /t reg_dword /d 1
reg add HKLM\SOFTWARE\WOW6432Node\Symantec\NPInstaller\DeclineCount\adobeebook /f /v nss /t reg_dword /d 2
Sep 18, 2019 Sep 18, 2019
Yes Enable Adobe Flash
Nov 19, 2020 Nov 19, 2020
The easiest way is to just add -PassThru (if you are using Powershell script)
Eg:
Execute-Process -Path "$dirFiles\ADE_4.5_Installer.exe" -Parameters '/S' -WindowStyle 'Hidden' -PassThru
Nov 25, 2020 Nov 25, 2020
Set-RegistryKey -Key 'HKLM\SOFTWARE\WOW6432Node\Microsoft\Windows\CurrentVersion\Uninstall\N360' -Name 'N360' -Value ''-Type String -ContinueOnError:$True
Sep 01, 2023 Sep 01, 2023
The only method I have found to deploy using MEMCM/SCCM is to repackage this installer using an MSI package builder. I use a product called EMCO but I'm sure other repackagers would work as well. I simply monitor the install, run through the install process and decline Norton. Then, package the delta into an MSI and deploy as you would any MSI.
