HI,
I am currently running Cold Fusion 11 with Update 3.
When I trying to compile Cold Fusion 11 to Java as part of the step so it can be scanned for potential issues with Veracode, the following message appears when trying to compile:
Could not fine or load main class coldfusion.tools.CommandLineInvoker
Per the link below Update 5 fixes the issue with the coldfusion.tools.CommandLineInvoker
ColdFusion 11 Update 5 prerelease build now available — Adobe ColdFusion Blog
But according to the article, Update 5 has an issue.
Update 7 is available. Has Update 7 fixed the issue with Update 5 and or the cfcompile?
Mike
What issue are you talking about in update 5? This bug was fixed in update 5 and the bugbase notes related to it show as fixed as well.
Will Update 5 fix the issue of not having the coldfusion.tools.CommLineInvoker in the lib folder?
Mike
See there is an issue with Update 7.
Does Update 6 have a corrected installed of Update 5 and that will provide a resolution to the missing coldfusion.tools.CommandLineInvoker file that cfcomplie is looking for?
Mike
