I bought e-books with two different adope it's. How could I change in the ebooks registration the adope it?
o.O Can not see your Answer.
wolfgangp24627306 schrieb:
o.o If you need help you should write anything.
I wrote the massage twice. I don't know why my text not visible. I try it now from my mobil phone: Thank you for the proposing solution. Unfortunately I use the Thalia eReader and I didn’t find it in the respective list
Diese Nachricht wurde von meinem Android Mobiltelefon mit 1&1 Mail gesendet.
Nanaky <forums_noreply@adobe.com>schrieb:
e-books with different two adope-it's.
created by Nanaky in Adobe Digital Editions - View the full discussion
The Link is for the IDs Vendor not from the eReader Manufacturer. Has you authorize your Reader with a adobe ID choose Adobe ID.
It works. Thanks a lot.
I'm a forum rooky and I don't find the "correct" button. Maybe you could close the thread as successful solved.
You are welcome.
This can make only you. Have you not any possibility under actions? (right under a answer).
