Moto,
Just some observations:
At first glance, what you may have to do is break your flash
content up into "segments" to overcome the 99 second limit for the
Presentation Settings feature. Not exactly ideal, but something
worth considering.
When you set the presentation's "time to wait" option to
zero, you absolutely got what you asked for; meaning that since
there's no audio on the slide with the flash anim, Presenter reacts
as if there's only static content on any given slide. And since you
set the flash anim to be controlled by the Presenter playbar, the
result is a flash anim that's stopped cold. Again, not good.
But beyond that, I have a couple of questions:
1. Have you tried using the Audio Editor feature? Using that
dialog box, you could enter as much silence (equal to the duration
of your flash file) to overcome the Presentation Settings limit. I
realize you don't want audio at the "slide level" in
PowerPoint...but adding silence in the Audio Editor can be used to
trick Presenter into thinking that there is audio. Couple that with
controlling the flash anim with Presenter's playback controls, and
you'll end up with the results you're looking for. In that same
vein, I've added over 4 mins of silence to a slide and had decent
results with the playback of flash anims.
2. If you really don't need any other elements stemming from
the PowerPoint environment, then why not kill off the Presenter
playbar altogether and just include some sort of playback controls
in the source flash file? This way, you won't have to deal with the
settings (or make adjustments to) the Presenter interface when the
deck is published.
Having said all that, let me offer one last bit of advice...
If your flash file is really long (such that you'd need more
than 99 seconds of silence!), then I'd strongly recommend that you
make a couple of adjustments to avoid playback problems. First,
make sure your flash anim is set to 30fps. Second, get a handle on
the TRT (total run time) of your flash movie. When you have that
number, be sure to add the same amount of silence in the Audio
Editor...BUT...back in flash, add one more second to the end of
your .fla. (make sure you extend the timeline of all visible
layers)
I've personally seen instances where swf files that have the
exact same duration as silence in PowerPoint result in "visual
stutters". By adding some "time padding", what this does is keep
the visuals playing according to the Presenter timeline at 30 fps,
while flash is “forced” to run at that same tempo; so
what happens is that the playback of the flash file becomes
slightly compressed, and most stutters are never seen!
Hope that helps!
Rob
visit my Presenter forums at:
www.robrode.com/yabb/
