Repeated tries and nothing happens when I double click on the install .exe. file. What now? Dell Pentium 4 GX260 running WinXP
If you're running XP with SP1 or SP2 this is most likely a certificate issue. The online installer is signed using sha256, which is not supported on XP SP1 or SP2. You can try the standalone installer posted at the bottom of the Installation problems | Flash Player | Windows 7 and earlier page in the 'Still having problems' section, however, there is no guarantee that it'll work. Essentially, XP SP1 and SP2 are lacking support for the latest cryptographic technologies necessary to sign binary installers. If it doesn't work, the alternative is to upgrade your system to something that supports the latest cryptographic technologies necessary to sign binary installers. You'll begin see similar behaviour (installers not working) with more applications as Microsoft will stop recognizing the validity of apps signed with the older sha-1 certificate in 2016 (see Security Advisory 2880823: Recommendation to discontinue use of SHA-1 - Security Research & Defense ...)
Maria
I am having the same problem with Vista. Everything was fine, but Firefox said it needed updated and then when I tried to, I had to uninstall and try to reinstall and now I cannot get Flash Player to install at all!
Any suggestions? Would an older version of Flash Player work and update, or is there a way to shut off the certificate thing?
Thanks.
Did the offline installer posted at Installation problems | Flash Player | Windows 7 and earlier work for you?
Assuming the installer is failing to execute due to the sha256 certificate issue, if you have Vista SP2, Microsoft does have an update to support sha256. Please see https://support.microsoft.com/en-us/kb/2763674 for more information.
Maria
