I have been away from RoboHelp for a while but now I am
working with a new install of version 7 with an old project
(upgraded from RH6). I am having trouble adding images to my
topics. Normally what I do is press CTRL+G to bring up the image
properties dialog, browse for the JPG image to add (it's path gets
placed in the Image name: field and a preview of my image is
shown), press OK and voila! The image appears in my file. Now I can
browse and select the image name but the preview and image name
fields are not updated. Pressing OK does not add the image to my
file. Has something changed in version 7?
Thanks in advance for any advice on this issue,
darkagn
The issue is occurring with both new projects and the sample
projects as well as my old, upgraded project. As this is a new
install, do you know if there is a patch that I can download that
has been released since version 7 was released?
Was the "new install" handled by IT? An RH install must be
done by you on your machine, with full admin rights. I know that IT
folks sometimes refuse to allow this, but "it is what it is." Also,
you should retain full admin rights at least until you've opened
one project.
It turns out that Update 7.0.1 referred to by Colum resolved
the issue. It had to do with my absolute file path for my images
being longer than 120 characters. I hadn't thought of this since
"standard" maximum length of file paths in Windows is 260
characters. Anyway, all solved now.
