Drop-down text not working in CHM (rh7)
Apr 14, 2008 Apr 14, 2008
I'm encountering a javascript error with my RH7 project:
When I generate a CHM file, the DHTML drop-down lists create a runtime error: "object expected". The object expected is "TextPopup(this)".
I'm creating the drop-downs with standard, highlight-and-insert, manner. The drop-downs work in WebHelp, and also worked in RH 5 before I imported the project. However, NO drop-downs work, project-wide, in the generated CHM.
Any ideas?
Sample code:
<p class=Body><a class=dropspot x-use-popup=#POPUP251245281 x-popup-type=pulldown
href="javascript:TextPopup(this)" id=a2>This is a test DHTML</a><robohelp><script
type="text/javascript" language=JavaScript1.2><!--
TextPopupInit('a2');
//--></script></robohelp></p>
540
Apr 15, 2008 Apr 15, 2008
Can you open one of the sample projects and add a dropdown to that?
Yes, and it works fine. I'm creating the Drop-downs by highlighting some text and selecting <b>DHTML > Create Drop-Down Hotspot and Text</b>
Apr 16, 2008 Apr 16, 2008
Is your project located on a network drive? If so, move it to a hard drive and see if that makes a difference.
Apr 21, 2008 Apr 21, 2008
No, it's on my hard drive. What I think I'll end up doing is restarting the project from scratch and just import everything. Not an ideal solution by any means, but i don't think i really have a choice ...
Engaged ,
That seems like an extreme response. If it will work with a sample project and not with your project try to find out what is different. Make sure that the correct javascript file is being included in your HEAD section. RoboHelp automatically includes a link to a .js file (eHelpDHTM.js, or something like that) file in every topic. This file should be in your root diectory. If this were missing or corrupt, you would get the error you report.
Good luck,
John
Apr 22, 2008 Apr 22, 2008
Try generating a CHM with EXACTLY the same name as the project.
myproject.xpj = myproject.chm
my_project.xpj = my_project.chm
etc.
RoboHelp Documentation
Download Adobe RoboHelp
