To make this work, go to Audio --> Edit --> Project audio. You can then insert slides at various points in the audio recording, and can drag them (just like closed captions) to the appropriate timing in the audio.
It is quite simple just:
1. Delete any audio files from your library so that you can start from scratch
2. At the top of the user interface select Audio
3. Hover over Import To
4. Select Background
5. Select the file from your browser
6. The Background Audio Dialog box will appear
7. As long as all of the options that you want are selected you can hit Close ("Save" is greyed out even though it seems like something you should hit before exiting..)
8. Preview your project and you should be all set to go!
Best Wishes,
Andraya
