alternative way of long cfif
Jun 06, 2007 Jun 06, 2007
anyone can help me to make this shorter or effective way? thank you!
Advanced techniques
721
Advocate ,
A couple of recomendations from looking at your code
1) If your code is getting a little verbose, switch over to using <cfscript>, its a little more condensed
2) You can shortcut myVar EQ "true" and myVar EQ "false" to just:
<cfif myVar> and <cfif NOT myVar> respectively
3) You don't need a <cfbreak> at the end of your <cfif> block.
4) I would recommend dropping the "variables." prefix. CF will treat unprefixed variables as being in the variables scope anyway (unless you are in a custom tag or User Defined Function)
Hope that helps.
It's not something I've confirmed recently, but IFAIK they're still
variables-scoped in custom tags. The variables scope being the *custom
tag's* variables scope, not the calling template's one.
Similarly my recollection of unscoped variables in a UDF *are* put in the
variables scope of the calling template. Where else would they go? (NB:
obviously if you VAR them first, they're in the magic scope-wth-no-name).
That said: the rest of your advice is sound.
Adam
Insuractive's advice is good. I'd add to that that TRUE and FALSE are
tokens, and don't need quotes around them.
My concern, though, is WTF you're doing with the REST of your code to
necessitate this sort of construct.
I think also it might be better to have "positive" sounding variable names:
doDEPQuery rather than skipDEPQuery. I presume at some point you have a
conditional around the <cfquery> tags, which will need to be negative if
you're setting a "skip" flag. The code will be easier to read if it's
positive.
Adam
Jun 07, 2007 Jun 07, 2007
Sometimes, when I have long list of variables to set as in your code, I do a loop on a list, like this
<cfscript>
my_skip="";
my_do="";
if(not variables.skipACTquery){
my_skip="skipDEPquery";
my_do="skipACTquery";
else if (not skipDEPquery){
my_skip="skipDIVquery";
my_do="skipDEPquery,skipACTquery";
else if(not variables.skipDIVquery){
my_skip="skipBCHquery";
my_do="skipDIVquery,skipDEPquery,skipACTquery";
else if (not variables.skipBCHquery){
my_skip="skipSECquery";
my_do="skipBCHquery,skipDIVquery,skipDEPquery,skipACTquery";
else if(not variables.skipSECquery){
my_skip="skipUNTquery";
my_do="skipSECquery,skipBCHquery,skipDIVquery,skipDEPquery,skipACTquery";
else if (not variables.skipUNTquery){
variables.usererrormsg = "error msgs."
</cfscript>
<cfloop list="#my_skip#" index="sdx">
<cfset variables[sdx]=false>
</cfloop>
<cfloop list="#my_do#" index="ddx">
<cfset variables[ddx]=true>
</cfloop>
Hope this helps
Ale
Engaged ,
Jun 08, 2007 Jun 08, 2007
Look into using CFCASE instead of cfifs...much easier to code.
Yeah, but each of the OP's conditional expressions are different. A SWITCH
won't work here.
Adam
actually there's a hidden performance hit if you use cfswitch w/non-numeric cases.
Jun 10, 2007 Jun 10, 2007
Tess_Gear, Adam's advice to use the positive variant of a variable name is a qualitative enhancement. Apart from that, I think your code is as short and as effective as it can be. The only thing I don't understand is the presence of the cfbreak tag.
Jun 11, 2007 Jun 11, 2007
I'd definitly think about another data-structure or otherwise rethink something.
However, your code follows a pattern, so the following code is definitly shorter, but a comment on the underlying pattern next to it is recommended:
To the human eye, perhaps. However, this is how Coldfusion "sees" your code:
Jun 12, 2007 Jun 12, 2007
Hey, the challenge was to either make it shorter OR more effective 😉 and mine is shorter to human eyes, just for the challenge!
I agree that my code is less effective, but the entire data-structure looks like an ineffective way to set up things IMHO.
Documentation
