adobe has upgraded to 4.5.1.133054 and DRM no longer works on the kobo glo HD
Have you check if your Reader authorize?
yes deauthorized and reauthorized on reader. reader show authorized
With the same Adobe ID as Digital Edition?
yes same id
Which error message you get exactly?
this document is protected by adobe digital rights management (DRM) and is not currently authorized for use with your adobe ID. Please sign in with your authorized Adobe ID and try again. have downgraded to drm v3 which does work with Kobo
O.o Has you try reset your reader and authorize new with your Adobe ID?
yes same message
Work any other eBooks? Sample eBook Library | Adobe Digital Editions
it worked on books already loaded that required drm. didn't try loading books from another source
Try you if work a sample file?
I just bought a KOBO Glow HD and tried to activate it thru ADE on my laptop (same ADE version).
Result: activation server error with an empty error code.and the message: Try again.
Kobo's solution is to deinstall version 4.5 and install version 3.. This worked for me but not happy to have to use and old version of DRM.
I de-installed version 4 and installed version 3 of ADE.
No change for me alas. Same problem: activation server error without an error code
