cfc to flex - not sure bug
Avatar
Former Community Member
I have coldfusion form and i would like to pass form value in
cfc using flex.
only problem i didn't see any example with cfc with where
condition. if u see artist example. bring all data..
I mean
select artistid, firstname, lastname, email
from artists where firstname like '#Arguments.firstname%#'
<noscript>
<object
classid="clsid:D27CDB6E-AE6D-11cf-96B8-444553540000"
id="test" width="70%" height="70%"
codebase="
http://fpdownload.macromedia.com/get/flashplayer/current/swflash.cab">
<param name="movie" value="test1.swf" />
<param name="quality" value="high" />
<param name="bgcolor" value="##869ca7" />
<param name="allowScriptAccess" value="sameDomain" />
<embed src="test1.swf quality="high" bgcolor="##869ca7"
width="600" height="400" name="test" align="middle"
play="true"
loop="false"
quality="high"
allowScriptAccess="sameDomain"
type="application/x-shockwave-flash"
pluginspage="
http://www.adobe.com/go/getflashplayer"
</embed>
</object>
</noscript>
<?xml version="1.0" encoding="utf-8"?>
<mx:Application xmlns:mx="
http://www.adobe.com/2006/mxml"
layout="absolute"
creationComplete="initApp()">
<mx:Script>
<![CDATA[
import mx.collections.ArrayCollection;
import mx.rpc.events.ResultEvent;
public function initApp():void
remoteService.getQuery();
</mx:Script>
<mx:RemoteObject
id="remoteService"
destination="ColdFusion"
showBusyCursor="true"
source="components.simple">
</mx:RemoteObject>
<mx:Panel label="Simple Grid" width="100%"
height="100%">
<mx:DataGrid id="mygrid"
dataProvider="{remoteService.getQuery.lastResult}"
width="100%" height="100%">
<mx:columns>
<mx:DataGridColumn dataField="artistid" />
<mx:DataGridColumn dataField="firstname" />
<mx:DataGridColumn dataField="lastname" />
<mx:DataGridColumn dataField="email" />
</mx:columns>
</mx:DataGrid>
</mx:Panel>
</mx:Application>
Avatar
Level 3
I kinda don't understand your question but if you want to use
flex to call a remote object and send a parameter to coldfusion you
just simply write something like this
remoteService.getQuery(param);
Where param can be a variable, an array , and so on. And in
coldfusion set an cfargument and that's it.
Avatar
Level 1
I will suggest since you are using coldfusion, why don't you
use cfc to responses to the request. You then can handle the return
result at whatever way you like.
Avatar
Level 1
in flex something like
<mx:RemoteObject id="Rservice" showBusyCursor="true"
destination="ColdFusion" source="cfc.MyServe">
<mx:method name="getsgentDatax"
result="dataHandler(event)">
<mx:arguments>
<p1> {firstname} </p1>
</mx:arguments>
</mx:method>
</mx:RemoteObject>
in cfc then you can use the query you use
and return as query
