Hello,
my coldfusion application runs in Intranet and Internet (https://www.xxx.com/inputform.cfm)
When I open my CF-Page from Internet, server side validation does not work.
No popup comes to tell that the required form field isn't filled out.
When I run the CF-Page as an internal Intanet application (http://servername/inputform.cfm)
the validation works fine.
Here is an example of an
<cfinput name="catalog" type="text" required="Yes" message="Catalog is required" >
Is https protocol the reason?
Best regard
Claudia
Fist guess, the CFIDE virtual directory is not configured for your external site. This directory contains a scripts folder that houses the JS files that the client-side CF validation requires. Next guess would be a JS error is being triggered, preventing the validation. Try running a client side debugging tool like Firebug in Firefox or the IE programmer tools. Either will point out the issue(s) of missing files or JS exceptions.
Lastly, I recommend getting away from using CFFORM, CFINPUT, etc.,
...Copy link to clipboard
Lastly, I recommend getting away from using CFFORM, CFINPUT, etc., for client-side validation. Use the native form and input tags and Incorporate something like jquery validation. It's much more state-of-the-art and gives you much more control over the user experience.
