I have started animating using Adobe After Effects CC 2015 and I have some issues regarding layers.
I am aware that I can trim them using option and the bracket keys, however, what I wanted to do was to split the layer so that it has a gap in between.
For instance, layer 1 is visible from 0:00 to 1:00, but what I wanted was to make it appear again at 2:00, leaving a blank section in the middle, from 1:00 to 2:00.
The only way I found to do this was to duplicate the layer then adjusting, yet it requires a huge amount of layers.
Is there any way of making it in the same layer?
Hey there,
To answer your question, there isn't a way to split your clip while keeping them on the same layer. Here's what we have available!
Hope this helps!
Caroline
Set in and out points using keyboard shortcuts Alt/Option + [ or ] for in and out.
Split layer at the CTI by pressing Ctrl/Cmnd + Shift + d
Type keyboard shortcuts in the Search Help field to locate many other useful shortcuts and techniques that any AE user should know.
Thank you!
No problem!
its command + shift + D on mac
No. You can do it in Premiere though. The stuff you're talking about sounds an awful lot like video editing. AE is not a video editing program. That kind of thing is much faster and easier in Premiere.
As Rick says, you can press CTRL/CMD+Shift+D to split a layer. You can then either trim the layer or move it to be a second further ahead, but it will be on a new layer. Alternatively, you could use hold keyframes on opacity to keep it on the same layer.
what about that if I press Alt+[ to cut the layer of text for example in after effect , it is working , could you explain please?
Hey there,
Hope this helps!
Caroline
