Digital Editions: I cannot open some of my books
Feb 04, 2016 Feb 04, 2016
I get the following error for 5 books in Digital Editions on my PC:
"Activation Server error
code : E_ACT_NOT_READY"
526
LEGEND , Feb 04, 2016 Feb 04, 2016
Macintosh:
  1. quit Adobe Digital Editions.
  2. Navigate to /Users//Library/Application Support/Adobe/Digital Editions and drag the activation.dat file to the trash.
    If you are using 10.7, see Access hidden library files | Mac OS 10.7 and later.
  3. Open Adobe Digital Editions and reauthorize.
Windows:
  1. Close all applications.
  2. Choose Start > Run.
  3. In the Open text box, type regedit and then press Enter. The Registry Editor opens.
  4. In the left pane of the Registry Editor, locate the following registry key: HKEY_CURRENT
[moved from Downloading, Installing, Setting Up to Adobe Digital Editions]
(you could google that error for a quick fix.)
Macintosh:
Windows:
  4. In the left pane of the Registry Editor, locate the following registry key: HKEY_CURRENT_USER\Software\Adobe\Adept
  5. Select the Adept key.
  6. Choose File > Export.
  7. In the Export Registry File dialog box, select Selected Branch under Export Range. Enter a name and location for the backup registry key, and then click Save.
  8. Right-click the Adept key and choose Delete.
  9. In the Confirm Key Delete dialog, click OK.
  10. Close the Registry Editor.
  11. Open Adobe Digital Editions and reauthorize.
Feb 05, 2016 Feb 05, 2016
Thanks for your assistance.
I followed the instructions faithfully.  However, the problem remains unchanged.
My PC's operating system is Windows 10 Home (I don't know if this make a difference).
Have you remove the Registry key and then authorize again?
I deleted the registry key.
I did not authorise D.E. because it is already authorised and I cannot de-authorise D.E.
When you remove the key its should deautorize. You make it as admin?
I have deleted the Key a few times.
Every time I open D.E. the Key returns to the registry.
I don't understand why or what to do about it.
I am the administrator for my PC.
o.O anything are on you system are wrong. When you remove the key its should not appear alone.
