I get the following error for 5 books in Digital Editions on my PC:
"Activation Server error
code : E_ACT_NOT_READY"
Macintosh:
Windows:
[moved from Downloading, Installing, Setting Up to Adobe Digital Editions]
(you could google that error for a quick fix.)
Macintosh:
Windows:
Thanks for your assistance.
I followed the instructions faithfully. However, the problem remains unchanged.
My PC's operating system is Windows 10 Home (I don't know if this make a difference).
Have you remove the Registry key and then authorize again?
I deleted the registry key.
I did not authorise D.E. because it is already authorised and I cannot de-authorise D.E.
When you remove the key its should deautorize. You make it as admin?
I have deleted the Key a few times.
Every time I open D.E. the Key returns to the registry.
I don't understand why or what to do about it.
I am the administrator for my PC.
o.O anything are on you system are wrong. When you remove the key its should not appear alone.
