Search function doesn't work in RoboHelp 7
Apr 21, 2008 Apr 21, 2008
I used to use RoboHelp X3 to create webHelp for Simplified Chinese and everying is working well.
Recently, I changed to use RoboHelp 7 as it supports Simplified Chinese.
I downloaded the trail version of RoboHelp 7 (for English windows) and follow the same way (i.e click "generat the primary layout for webhelp") as with RH X3 to create a webHelp. After done, I view the output and frustrated to see neither index is created nor search works (no topic found when search any word).
My question is
1. Will index not created automatically this way? Do I have to run "smart index wizard" to genearte index?
2. I really have no idea why search funtion doesn't work at all. Is it becasue this is a trial RH verson or is any of my setting or step incorrect?
Thanks for anyone's kind help or tip. I studied a lot and still couldn't find out the reason.
Annie
855
Welcome to the forum
First, the trial version is not limited in any way except the 30 days use.
Second, try installing the update as that did fix a number of issues that are relevant.
Hi, Peter,
Thanks for your reply.
I downloaded RH 7 trail version only this Monday (April 21) from Adobe website. It didn't indicate the exact build.
You said try to install the update. Could you let me know where can I find the update version? Thanks much!
Annie
Help | Updates on the RH menu.
May 05, 2008 May 05, 2008
thanks, Peter. Unfortunately, update couldn't help either. I'm now thinking to buy a set of Robohelp 7.0. Hope this will resolve my problem.
The trial version has exactly the same functionality as the full version. If the trial and the update has not fixed your problem, then you need to find the solution first.
There is information on my site in Using RH7 that may help.
May 09, 2008 May 09, 2008
Dear Freind
There is no need to worry about the Search Problem. You are using RoboHelp 7. First Step Go into View Menu and then Click on PoDs and expand it.
Second step:Project Manager Pane opens up. Make a folder in it since there is an option, or if you have any problem to find fit try to right click on HTML Project Files. Start Making the topics in it and then generate your webhelp.
You can run the Smart Index Wizard and You can manually create it as well.
Cheers
Addnan
May 13, 2008 May 13, 2008
Dear Peter,
I met the following problem, and please help me.
My English (not Chinese) operating system: Windows XP
Version: 2002
Before using RoboHelp 7 to generate Webhelp, I perform the following steps:
1. Control Panel->Regional Options
2. On the "Languages" page make sure make sure you check the box "Install files for East Asian languages".
3. On the "Advanced" page select "Chinese" from the language dropdown list.
Then I perform the following steps:
1. Use RoboHelp 7 to generate Webhelp (my Webhelp project contains localized Chinese files).
2. In the "Search" tab, input a Chinese character(For example "连接") and perform a seach.
Result: Serching...(or 正在搜索) or No topics found (or 未找到主题)。
Expected result: I can get the result.
Text
RoboHelp Documentation
Download Adobe RoboHelp
