cfzip unzip to browser
Feb 07, 2016 Feb 07, 2016
Is there a way to unzip without writing the PDF file inside the zip to disk but directly to the browser for downloading?
533
LEGEND , Feb 08, 2016 Feb 08, 2016
Depending upon what version of CF server you're using, it would be like this.
Say your .zip file is located at C:\userguide.zip, and it contains one PDF file, userguide.pdf.
<cfzip file="C:\userguide.zip" action="list" name="filez" />
<cfzip file="C:\userguide.zip" action="readBinary" entrypath="#filez.name#" variable="thisFile" />
<cfheader name="Content-Disposition" value="inline; filename=#filez.name#" />
<cfheader name="Content-Type" value="application/pdf" />
<cfcontent type="application/p
<cfcontent type="application/pdf" variable="#ToBinary(thisFile)#" reset="true" /><cfabort>
HTH,
^_^
UPDATE:  Very important that the filename of the PDF not contain any spaces, slashes, backslashes, etc.  Replace all of these with underscore, if you must.
UPDATE2:  I should also note that the above should be the only code on the page.  Anything before the above will break the process, and anything after will be ignored.
The CFABORT is if you are redirecting to this page from another, then this will offer the PDF to stream without actually going to the page in the browser - it will offer the file, but appear as if it's running in the background.
Feb 14, 2016 Feb 14, 2016
Thank you, that worked perfectly!
Feb 16, 2016 Feb 16, 2016
Glad you got it working, and thank you for marking my answer correct.
V/r,
^_^
Documentation
