How to put values in list with single quotation
Feb 08, 2016 Feb 08, 2016
<cfquery name="getSelectedPriorityList" datasource="#application.datasource#" username="#application.datasource_username#" password="#application.datasource_password#">
  SELECT  id, name
  FROM  lrp,  p
  WHERE lrp.id = p.id
  AND lrp.ra_id = 123
  AND lrp.id in (#form.assignedPriority#)
</cfquery>
<cfset nickname_list=Valuelist('getSelectedPriorityList.name')>
If I run above code the value of nickname_list =  Send Certificate Invitation,View Certificate,Allow Key Recovery
but
I am in need the output as nickname_list =  'Send Certificate Invitation','View Certificate','Allow Key Recovery'
Kindly let me know what exactly I need to do to generate above output.Thanks in Advance
224
You _should_ be using CFQUERYPARAM for the values, just for security.  However, the CFQUERYPARAM has an attribute "list" that might fix it.  If not by itself, you might be able to use QuotedValueList().
HTH,
^_^
Feb 09, 2016 Feb 09, 2016
list attribute worked perfectly..Thanks a lot for the response
Guide ,
How are you using nickname_list later in your code?  Why does it need to be single-quote delimited?  You might also considering storing the value in an array rather than a list, depending on how you use it later.
Thanks a lot
Carl Von Stetten
Documentation
