Is there a way to capture the value passed in the referrer? I need to capture that and do some searching.
Okay, so all I have to do to get the URL parameter value is URL.variable name.
<cfhttp url="https://app.knowledgeowl.com/api/head/article.json" method="get" timeout="15">
<cfhttpparam type="url" name="_authbykey" value="56a7d8c532131c4058362589">
<cfhttpparam type="url" name="project_id" value="55c4ffd258561c527e294fe6">
<!---<cfhttpparam type="url" name="url_hash" value="calendar">--->
<!--- Pass along any URL values. --->
<cfhttpparam type="url" name="url_hash" value="#URL.
...Copy link to clipboard
Can you elaborate a what "value" you are talking about? Please be specific.
I guess I can use <cfdump var="#CGI#"> to show and then get my values from the QUERY_STRING.
Possibly. But keep in mind that dumping the CGI scope won't necessarily reveal every attribute available. Depending on the web server you are using, it may populate CGI variables that don't show in CFDUMP - you just have to know what they are and access them directly (as CGI.some_obscure_variable).
What referrer information are you looking for? From my local CF10 development environment, it looks like the CGI.HTTP_REFERER variable contains the full URL (including query string) from the referring page. Is that what you were looking for?
I'm looking for the parameter value that's being passed from the previous page.
Again, can you be specific? What parameter are you referring to? A URL parameter? If so, it will likely be in the CGI.HTTP_REFERER variable, but you'll have to parse the whole URL to find the parameter you are looking for. This CFLib function might help.
In the Referrer it looks like this: https://www.mysite.com/search/?search=basics
and I want to get the value of the parameter "search". In this case the value is "basics". I don't know if this is through the URL or not but this is what is showing under the Net/XHR/Headers in firebug.
If you take the URL and treat it like a list with '?' as the delimiter, using the second index you'll get "paramName=paramValue". Take this value and (again) treat it like a list with '=' as the delimiter, you'll get index1 as the parameter name and index2 as the value.
This is assuming that there is only ONE URL parameter passed. If there are more than one, you'll have to insert another process to see a list using '&' as the delimiter. The downside to that is that any value having a '&' in it will give a false indication of where the list actually is.
HTH,
^_^
I think the CFLib function I provided a link for does all of what WolfShade‌ mentioned for you. Essentially, you pass it the full URL (like https://mysite.com/search/?search=basics) and the parameter name you are looking for (like "search") and it will return the parameter's value (like "basics").
Here are some other related and useful UDFs from CFLib.org:
CFLib.org – QueryStringChangeVar
CFLib.org – QueryStringDeleteVar
-Carl V.
Carl,
I'm trying out the function you posted above and for some reason it's returning blank. Below is my code:
<cfhttpparam type="url" name="_authbykey" value="56a7d8c123131c4058361789">
<cfhttpparam type="url" name="project_id" value="55c4ffd456131c527e7899fe6">
<cfhttpparam type="url" name="url_hash" value="#queryStringGetVar(CGI.http_referer, 'slug')#" />
<cflog text="URL-Hash: #queryStringGetVar(CGI.http_referer, 'slug')#" type="Information" file="CGIparameters">
</cfhttp>
<cfscript>
* Gets the value of a variable in a query string.
* @param query_string The query string to examine. (Required)
* @param this_var_name The variable to look for. (Required)
* @return Returns a string.
* @author Shawn Seley (shawnse@hotmail.com)
* @version 1, August 1, 2005
function queryStringGetVar(querystring, this_var_name){
var re_found_struct = "";
querystring = trim(querystring);
re_found_struct = REFindNoCase("(^|[\?|&])#this_var_name#=([^\&]*)", querystring, 1, "true");
// = re_found_struct.len & re_found_struct.pos
if(arrayLen(re_found_struct.pos) gte 3) {
if (re_found_struct.pos[3] GT 0) return urlDecode(mid(querystring, re_found_struct.pos[3], re_found_struct.len[3]));
else return "";
} else return "";
</cfscript>
The log shows blank. So, I'm not quite sure why. The CGI.http_referrer shows this: https://devbox.mysite.com/kb/?slug=calendar
<cfhttpparam type="url" name="url_hash" value="#URL.slug#" />
<cflog text="URL-Hash: #URL.slug#" type="Information" file="CGIparameters">
</cfhttp>
Hello - we are currently getting the domain of the referrer. This is working. We need help getting the full path of the referring url.
For example...
Lets say someone comes from google using this search
We are already getting:
but how do we go about getting the rest of that string?
or just
search?q=tax+preparation+08816
Next example:
https://antonuccilegal.com/blog/new-jersey-auto-insurance-consumers-have-rights/
If this was referrer url, we would get...
but we want full path
We are running Coldfusion 2016 and need some guidance.
You cannot rely on the referrer value. It's not guaranteed to have a useful value.
The User Agent (Web browser) controls what value you will see and it will be different for each of your visitors depending on their User Agent and its settings.
