Hello, I became a member of the Goethe Institute library and downloaded a file in the Adobe Digital Edition format. I downloaded Adobe Digital and initially just authorized my computer (without an ID), but then realized this was wrong and created an account under my e-mail address. I can open and read the in Adobe Digital Edition on my computer, but for some reason I cannot transfer it to my Tolino e-reader (the option is grayed out).
I then tried to transfer it with Calibre (which worked), but when I tried to open it (using the same Adobe ID I use on my computer) I got this error message:
"The content protected by Adobe DRM could not be loaded. The Adobe ID does not match the one saved in the tolino. Please check the settings on your tolino to determine which Adobe ID you have saved.(Cause of Adobe error: E_ADEPT_CORE_USER_NOT_ACTIVATED)
But the ID's are the same!! So I don't know what is causing this
Can you help, please?
Macintosh:
Windows:
If you open the ebook with the empty authorize its linked with this authorize. So you can it read only on Digital Edition. If you want used it on a other device must authorize Digital Edition with our Adobe ID and ask for a new Download without a authorize.
I tried to authorize Digital Edition with my Adobe ID, but it won't let me - This is the Adobe ID I am using on my Tolino which should be identical, no? So I don't understand why Adobe won't let me authorize this.
Kind Regards
Jutta
Macintosh:
Windows:
Thank you Nanaky, it worked
You are welcome.
