Locked
2
Is it possible to use Recaptcha V2 with BC?
Feb 09, 2016 Feb 09, 2016
I'd like to implement the Recaptcha V2 module, (https://developers.google.com/recaptcha/intro)? It requires the challenge response to be verified server side, so I'm trying to find out if BC has implemented the server side code to allow for it to be used instead of the old version?
Regards, Mark.
3rd party integration
3.7K
Adobe Employee , Feb 14, 2016 Feb 14, 2016
It will be available at the end of next week
Not till BC introduce it themselves.
Feb 10, 2016 Feb 10, 2016
Thanks Liam.
BC Team, is Recaptcha V2 on the radar?
Regards, Mark
Adobe Employee ,
Contributor ,
Feb 16, 2016 Feb 16, 2016
Ref Cristinel's post on R212:
Added the ability to use the new Google reCaptcha on web forms (original idea: https://forums.adobe.com/ideas/4297)
It works great on webforms, we started updating our forms already.
But will the new reCaptcha be available also blog comments, Forum posts, etc (In Site settings, Captcha nothing's changed).
You can not just flick a switch and change stuff, you will have to implement it on most forms you build, just as you would v2 captcha from v1 or the recpatcha modules.
Thanks for the update, Mihai. I've added it to a site today and it works a treat.
For those wondering how to implement, replace the existing captcha (v1 or v2) or recaptcha label and module with the following,
<label>Prove you're not a robot <span class="req">*</span></label>
{module_recaptcha version="2"}
and replace the validation script in the form's js with:
if (theForm['g-recaptcha-response']) why += reCaptchaV2IsInvalid(theForm, "Please prove you're not a robot");
Regards, Mark
Contributor ,
Feb 17, 2016 Feb 17, 2016
Hi Mark and thanks for your input,
It works perfectly on standard webforms.
On comments, when the form is reinserted, the new validation script is automatically added but there seems to be still an issue with the validation message, as BC returns an error, even when it's validated on the recaptcha module (not a robot).
testpage
Support is looking into it.
Hey, always glad to help where I can...
It looks as if you still have the CaptchaV2 javascript inserted as well as the new code..., have you tried it with that removed?
if (theForm.CaptchaV2) why += captchaIsInvalid(theForm, "Enter Word Verification in box below",
                                "Please enter the correct Word Verification as seen in the image");
Have you tried it with that removed and just with the validation below?
Contributor ,
Yes, we tried that it's the same.....
Just updated the script. Do you get this working?
No, it's not working for me, either. I did what you had tried, added a comment form to an empty page, it's passing the javascript validation but failing the backend check. I checked/modified the code so that it was the same as that used on the webforms that I have working, but it's still throwing the same error.
Contributor ,
Just got the confirmation from support that it's not functional.
They have escalated the {module_recaptcha version="2"} working in Comments as 'Feature Request'.
Let's see.
Contributor ,
Feb 21, 2016 Feb 21, 2016
With the assistance from support: the issue can be solved by unchecking the Site settings/Captcha/Comments Option.
You still add the {module_recaptcha version="2"} to your form.
Mar 22, 2016 Mar 22, 2016
Hi all,
I have a little more information on the workaround mentioned by Eworks-WSI, hopefully it'll save others the couple of hours I spent thinking I was doing something wrong.
If you're trying to add recaptcha version 2 to a comment form and you're getting the validation error after submission, when you try the workaround of unchecking the comments from Site Settings --> Captcha, you may find that the checkbox is disabled but checked. Apparently, this is disabled when the comment count on the site exceeds 500, so in order to get the recaptcha v2 working in this situation, you will need to delete comments until there are less than 500, if you can. This will enable the checkbox and once you uncheck it, the recaptcha will submit successfully.
Hope that helps.
Regards, Mark.
