I have a form with a flowed subform, containing several fields.
I need all the fields in the subform to expand in height to fit the height of that particular field that is filling.
How can I make all the fields in the subform expand in height when the one field expands?
Thank you for any assistance on this.
Here is a screenshot showing the issue with the subform. The fields started as two lines in height. I typed in three lines and the field expanded, as I needed it to, but the other fields in that row did not expand in height. Need them to expand in height as well. Must be subforms - can't be a Row. Autofit for the subform height is checked off and grayed out.
Total Likes
I found the code on the web which partially accomplishes what I am trying to do. I put the code below in the ready.layout event of the other fields in the subform.
var heightField = xfa.layout.h(xfa.resolveNode("PPDescription"), "pt");
his.h = heightField + "pt";
There are button son the form to add and remove rows of the subform. The problem I have now is that although all the field heights now match, when I press the button to remove a row, there is a space below all the fields before the next subform row below - need to eliminate that space.
Total Likes
