Brand new CF 11 install on Windows 2012 R2. I have a cluster of servers running so I disable the client variable purge process on ALL serves. Although the purge process is disabled I still see "Run Client Storage Purge" messages in the coldfusion-out.log. I want to ensure client variable purge is NOT running on each server.
Is that CFadmin > Server Settings > Client Variables > Purge Interval ?
Regards, Carl.
Purge interval is set to the system default of 1 hour and 7 minutes (kind of an odd number). If you click the database name used for client variable storage it takes you to an additional configuration screen where you can essentially enable or disable the purge process. I have it disabled yet I still see the "run client storage purge" entry in the coldfusion-out.log file.
