I find this one rather annoying, in the latest verison of Adobe Photoshop CS6 when creating an animated GIF via the Save for Web dialog box; there is a looping option section that allows your animation to loop forever, or once...
In the previous version, it would remember which setting you selected for subsequent saves. In this new version, it forgets it and always defaults to ONCE; where I want FOREVER... making me forget to check it sometimes, when I'm working fast; and create animations that stop after one loop...
Anyone else experience this annoyance?
-Joe
Yes, I noticed it. I can confirm what you're seeing.
I make it a habit to test the animation, and when I see it stop it reminds me to change the option.
But like you when I do animations I virtually always want them to loop, and having the setting "stick" would be nice.
-Noel
The setting seems to stick with an image, new images are assigned »once« – I guess a Feature Request might be called for
Seems like people shouldn't have to re-request features that were already features in the last version.
Either Adobe took the "stickyness" of that setting out on purpose, in which case I'd expect nothing more will be done, or they left it out accidentally with the restructuring of the Timeline window, in which case it would be a bug, no?
But Christoph is right in either case - you can help ensure it is seen by posting it on the http://feedback.photoshop.com/photoshop_family/ site.
-Noel
I found a solution to this in todays version of Photoshop. When saving for web, under the Color Table and Image Size in the Save for web window there is a field called Animation. Setting Loop option to Forever made my GIF loop around.
I figured out a work around for this issue. I needed to make 30 looping animated gifs of 1080p footage shrunkin down for the web and this is what my action looks like:
Now that we went through that process the animation type will be set to "forever" and it will apply to any videos in your batch that you automate.
What the history of the action looked like
Is this solved on the latest version? I'm running 2015.0.1 and it seems that nothing has changed.
Still not fixed. I don't understand why 'once' is the default, anyway. I'd encourage adobe to run some analytics on how often people actually export gifs that only run once. Seems very rare, if it is the case very user hostile to have it as the default.
I see the problem is still actual, I am using adobe photoshop 2019 version, but the same problem still exists. Haven't you found a solution to this sproblem yet?
Anyone found a work around to this yet? How is it possible that there are settings available to select that just don't work...! Adobe this is a serious error in your programming!
Found a solution! Was driving me crazy as well. In the lower left of the timeline panel there is dropdown for looping options. Create an action changing this to "forever", then when you save for web it will stick. Save the action and batch the rest of your .gifs
Working from the butt, but working
