Problem with return a ColdFusion query object from a Java class
Jun 06, 2007 Jun 06, 2007
Hi!
I need to return a ColdFusion query object from a Java class using a JDBC result set ( java.sql.ResultSet);
I have tried to pass my JDBC result set in to the constructor of the coldfusion.sql.QueryTable class with this code:
ColdFusion code
<cfset pra = createObject("java","QueryUtil").init()>
<cfset newQuery = CreateObject("java", "coldfusion.sql.QueryTable")>
<cfset newQuery.init( pra.getColdFusionQuery () ) >
My java class execute a query to db and return QueryTable
Java code (QueryUtil.java)
import coldfusion.sql.QueryTable; // (CFusion.jar for class QueryTable)
import com.allaire.cfx //(cfx.jar for class Query used from QueryTable)
public class QueryUtil
public static coldfusion.sql.QueryTable getColdFusionQuery(java.sql.ResultSet rs)
return new coldfusion.sql.QueryTable(rs);
but when i run cfm page and coldfusion server tries to execute : "<cfset pra = createObject("java","QueryUtil").init()>" this error appears:
Object Instantiation Exception.
An exception occurred when instantiating a java object. The cause of this exception was that: coldfusion/sql/QueryTable.
If i try to execute QueryUtil.java with Eclipse all it works.
Also I have tried to return java.sql.ResultSet directly to coldfusion.sql.QueryTable.init () with failure.
Do you know some other solution?
Advanced techniques
6.3K
Explorer , Jun 25, 2007 Jun 25, 2007
thanks cf_dev2
This is the solution:
if you use other jar file in your java.class, you must write the jar's path in the jvm classpath:
-- open C:\CFusionMX7\runtime\bin\jvm.config with text editor;
-- add at the bottom the full path fo your jar files
-- save
-- restar coldfusion
i thing that you can also add classpath in coldfusion administrator, but i don't know how;
i found only CF classpath.
hi to all.
Advocate ,
You can go down the serializable route and convert your java recordset into something that you can load into CF (e.g. WDDX, XML, JSON). That way you get a plain text result from java that you can load into CF. Personally I'd go with WDDX. I'm sure there are some Java WDDX functions and you can use <cfwddx> to convert it to a CF query (pretty fast).
Engaged ,
Why are you trying to return a ColdFusion Query? Usually you would return a native Java datatype like a Vector of value objects. Otherwise your going to have to construct a query in ColdFusion which is extra looping.
Guide ,
ik1hsr,
I think there are some other problems with the code, but to start with:
[ColdFusion code]
[/ColdFusion code]
The getColdFusionQuery() method already returns a "coldfusion.sql.QueryTable" object. So technically you don't have to create another one.
[ColdFusion code]
[[/ColdFusion code]
The getColdFusionQuery() method expects a parameter of type java.sql.ResultSet. But you're calling the method without passing in any parameters.
You might want to review the cfx classes. Specifically the addQuery() method.
Jun 11, 2007 Jun 11, 2007
I have modified my code:
[Coldfusion code]
rs = st.executeQuery("SELECT * FROM Table");
ourQuery = createObject("java","QueryUtil").getColdFusionQuery(rs);
[/ColdFusion code]
java class
public static QueryTable getColdFusionQuery(java.sql.ResultSet rs) throws java.sql.SQLException
return new QueryTable(rs);
But when i run it occurs the same error:
Do you know why??
Guide ,
ik1hsr,
Can you explain your overall goal? I ask because typically you don't create a java resultset in ColdFusion code. You simply use cfquery.
<cfquery name="YourQuery" datasource="YourDatasource">
SELECT * FROM Table
</cfquery>
This creates a query object named "YourQuery" that you can use in your ColdFusion code. So there is no need to create a java resulset.
Are you trying to do something different?
Yes, i need to use this java.class...
..now i'm trying to serialize the ResultSet and use it in CF with WDDX....
Jun 12, 2007 Jun 12, 2007
this is the reason for which i can't use CFQUERY
-- I have cfc component that implements my Business logic (some sql query)
-- I need to create a java class to replace this cfc.
Advocate ,
I don't know if it helps, but I found this page with the properties / methods for QueryTable:
http://www.zrinity.com/developers/mx/undocumentation/query.cfm
Do you still get the same error if you try an instantiate the object using the default constructor:
return new QueryTable();
If so, I would theorize that perhaps the CF java objects are protected somehow. Though it doesn't seem so from the link I just mentioned.
thanks for the reply,but i search in google for a week.....
Advocate ,
Have you tried recreating the entirety of the java code in CF using createObject()?
objQT = createObject("java","coldfusion.sql.QueryTable");
<!--- Try init() or populate() --->
objQT.init(rs);
<!--- or --->
objQT.init();
objQT.populate(rs);
Then do a dump of objQT and see what you get?
Guide ,
ik1hsr,
I haven't tried it, but functionally insuractive's suggestion sounds right.
Why switch from cfc's to a java class? Is it a business requirement or some other reason? I ask because: at a basic level cfqueries _may_ be faster than creating your own resultsets. ColdFusion can utilize connection pooling. If you create your own resultsets, I don't think you have that advantage, unless you implement it yourself (or find a way to use CF's pooling). So I think you still have the overhead of opening a connection for each query, which can slow things down.
it's a business requirement;
Java class implements some method such as search(...),update(...),delete(...),insert(....),new(....)
In coldfusion i use this java class to replace a cfc that implements the same operation.
Someone knows a valid method to pass a ResultSet from JAVA to ColdFusion Query?
I have tried to use the code of this site:
http://www.petefreitag.com/item/73.cfm
But the problem is the same one of the previous post
Jun 13, 2007 Jun 13, 2007
stack trace
java.lang.NoClassDefFoundError: coldfusion/sql/QueryTable at java.lang.Class.getDeclaredMethods0(Native Method) at java.lang.Class.privateGetDeclaredMethods(Class.java:1655) at java.lang.Class.privateGetPublicMethods(Class.java:1778) at java.lang.Class.getMethods(Class.java:832) at coldfusion.runtime.java.ObjectHandler.Initialize(ObjectHandler.java:40)
Guide ,
import java.sql.SQLException;
public class QueryUtil {
throws SQLException {
... (create resultset code) ...
<cfset newQuery = createObject("java","QueryUtil").getColdFusionQuery(rs) />
<!--- must close resulset when finished --->
<cfset rs.close()>
<cfdump var="#newQuery#">
ok
i print all my code
pratica.java execute a query to db and return a querytable
java class
import java.util.*;
import java.sql.*;
import coldfusion.sql.*;
public class Pratica {
private HashMap my;
private String URI,LOGIN,PWD,DRIVER;
private Connection conn=null;
//funzione init
//riceve due strutture converite in hashmap
// globals
// dbprop
public Pratica(HashMap globals,HashMap dbprop) {
my = new HashMap();
my.put("GLOBALS",globals);
my.put("DBPROP",dbprop);
URI = "jdbc:sqlserver://it-bra-s0016;databaseName=nmobl";
LOGIN = "usr_dev";
PWD = "developer";
DRIVER = "com.microsoft.sqlserver.jdbc.SQLServerDriver";
try{
// Carico il driver JDBC per la connessione con il database MySQL
Class.forName(DRIVER);
/* Connessione alla base di dati */
conn=DriverManager.getConnection(URI,LOGIN,PWD);
if(conn!=null) System.out.println("Connection Successful!");
} catch (ClassNotFoundException e) {
// Could not find the database driver
System.out.print("\ndriver non trovato "+e.getMessage());
System.out.flush();
catch (SQLException e) {
// Could not connect to the database
System.out.print("\nConnessione fallita "+e.getMessage());
System.out.flush();
//funzione search
//riceve un hash map con i filtri di ricerca
public QueryTable search(/*HashMap arg*/) {
ResultSet rs=null;
Statement stmt=null;
QueryTable ret=null;
String query="SELECT * FROM TAN100pratiche";
try{
stmt = conn.createStatement();// Creo lo Statement per l'esecuzione della query
rs=stmt.executeQuery(query);
// while (rs.next()) {
// System.out.println(rs.getString("descrizione"));
catch (Exception e) {
e.printStackTrace();
try {
ret = Pratica.RsToQueryTable(rs);
} catch (SQLException e) {
this.close();
return(ret);
// ret=this.RsToQuery(rs);
// this.close(); //chiude le connessioni,recordset e statament
//retstruct CF vede HashMap come struct
//METODO DI TEST
public HashMap retstruct(){
return(my);
//conversione resultset to querytable
private static QueryTable RsToQueryTable(ResultSet rs) throws SQLException{
//chiura resultset statament e connessione
private void close(){
try{
conn.close();
conn=null;
coldfusion code
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
<html>
<head>
<title>Test JDBC CFML Using CFScript</title>
</head>
<body>
<cftry>
<cfset glb_map = createObject("java","java.util.HashMap")>
<cfset dbprop_map = createObject("java","java.util.HashMap")>
<cfset glb_map.init(glb)> <!---are passed from another page--->
<cfset dbprop_map.init(glb["DBPROP"])>
<cfset pra = createObject("java","Pratica").init(glb_map,dbprop_map)>
<cfset ourQuery =createObject("java","coldfusion.sql.QueryTable").init(pra.search())>
<cfcatch>
<h2>Error - info below</h2>
<cfdump var="#cfcatch#"><cfabort>
</cfcatch>
</cftry>
<h2>Success - statement dumped below</h2>
<cfdump var="#ourQuery#">
</body>
</html>
error at line <cfset pra = createObject("java","Pratica").init(glb_map,dbprop_map)>
Guide ,
What about the stack trace error?
Message
StackTrace
java.lang.NoClassDefFoundError: coldfusion/sql/QueryTable at java.lang.Class.getDeclaredMethods0(Native Method) at java.lang.Class.privateGetDeclaredMethods(Class.java:1655) at java.lang.Class.privateGetPublicMethods(Class.java:1778) at java.lang.Class.getMethods(Class.java:832) at coldfusion.runtime.java.ObjectHandler.Initialize(ObjectHandler.java:40) at coldfusion.runtime.java.ObjectHandler.<init>(ObjectHandler.java:26) at coldfusion.runtime.java.ReflectionCache$1.fetch(ReflectionCache.java:27) at coldfusion.util.WeakKeyCache.get(WeakKeyCache.java:40) at coldfusion.runtime.java.ReflectionCache.get(ReflectionCache.java:33) at coldfusion.runtime.java.JavaProxy.<init>(JavaProxy.java:27) at coldfusion.runtime.CFPage.createObject(CFPage.java:5783) at coldfusion.runtime.CFPage.CreateObject(CFPage.java:5677) at coldfusion.runtime.CFPage.CreateObject(CFPage.java:5642) at cftest_java_22ecfm1357198390.runPage(C:\CFusionMX7\wwwroot\gruppotesi\goldenring\airone\core\framework\util\test_java_2.cfm:14) at coldfusion.runtime.CfJspPage.invoke(CfJspPage.java:152) at coldfusion.tagext.lang.IncludeTag.doStartTag(IncludeTag.java:349) at coldfusion.filter.CfincludeFilter.invoke(CfincludeFilter.java:65) at coldfusion.filter.ApplicationFilter.invoke(ApplicationFilter.java:225) at coldfusion.filter.RequestMonitorFilter.invoke(RequestMonitorFilter.java:51) at coldfusion.filter.PathFilter.invoke(PathFilter.java:86) at coldfusion.filter.LicenseFilter.invoke(LicenseFilter.java:27) at coldfusion.filter.ExceptionFilter.invoke(ExceptionFilter.java:69) at coldfusion.filter.BrowserDebugFilter.invoke(BrowserDebugFilter.java:52) at coldfusion.filter.ClientScopePersistenceFilter.invoke(ClientScopePersistenceFilter.java:28) at coldfusion.filter.BrowserFilter.invoke(BrowserFilter.java:38) at coldfusion.filter.GlobalsFilter.invoke(GlobalsFilter.java:38) at coldfusion.filter.DatasourceFilter.invoke(DatasourceFilter.java:22) at coldfusion.filter.RequestThrottleFilter.invoke(RequestThrottleFilter.java:115) at coldfusion.CfmServlet.service(CfmServlet.java:107) at coldfusion.bootstrap.BootstrapServlet.service(BootstrapServlet.java:78) at jrun.servlet.ServletInvoker.invoke(ServletInvoker.java:91) at jrun.servlet.JRunInvokerChain.invokeNext(JRunInvokerChain.java:42) at jrun.servlet.JRunRequestDispatcher.invoke(JRunRequestDispatcher.java:257) at jrun.servlet.ServletEngineService.dispatch(ServletEngineService.java:541) at jrun.servlet.http.WebService.invokeRunnable(WebService.java:172) at jrunx.scheduler.ThreadPool$DownstreamMetrics.invokeRunnable(ThreadPool.java:318) at jrunx.scheduler.ThreadPool$ThreadThrottle.invokeRunnable(ThreadPool.java:426) at jrunx.scheduler.ThreadPool$UpstreamMetrics.invokeRunnable(ThreadPool.java:264) at jrunx.scheduler.WorkerThread.run(WorkerThread.java:66)
Guide ,
I think you forgot to import the jdbc driver class. There are different versions, so check the package path may not be correct for your version.
import java.util.*;
import java.sql.*;
import com.microsoft.sqlserver.jdbc.*; // <!---- import jdbc driver
Guide ,
Test the class in your java IDE first - before trying it with ColdFusion:
import java.util.*;
import java.sql.*;
//.... declarations, other methods ... etcetera
public static void main(String[] args) {
//test java class
Pratica p = new Pratica(new HashMap(), new HashMap());
p.close();
Jun 14, 2007 Jun 14, 2007
ok i'll try...
Jun 20, 2007 Jun 20, 2007
I have tried to import jdbc driver but occurs the same error.......
in my java IDE it works......
Guide ,
Jun 21, 2007 Jun 21, 2007
Are the sql server jdbc jars in the CF classpath?
yes
Guide ,
Did you restart CF after replacing the .class file with the newer version? It may still be using the old class file.
If not, can you post the error, with the cf code line.
Documentation
