How can I get the search function to work? I type in a specific word, but it only says "no matches found" - although I know that there are plenty of matches in the e-book. I've tried re-downloading the book without luck.
Has you the same problem with a other ebook also?
I only have one. But the "Getting Started" file works perfectly with the search function. Also, I can't highlight anything. I have a Mac.
It seems the eBook are not format that you can used the search function. Have the same problem in any files and other files work perfectly.
So I can't do anything to change that?
No. Can only ask the creater if can change it...
This is happening w/me in WebHelp. Very frustrating. It happens only with certain single terms. Other times, a single word works just fine.
Its a problem how create the ePub file. In this case you can nothing do.
